Old 08-20-2014, 01:16 PM   #1
whip
Drives: 2014 FRS MT
Which LED bulb/socket?
I'm trying to mod my rear reflector to function as an additional brake light but am having trouble deciding which bulb and socket to use. I want it to be a red LED and dual filament so it can come on with the headlights and get brighter when I hit the brakes.
I have looked at some DIY articles here and can't find the information I need. One write up uses 2 bulbs (I just want to use 1) and some of the other write ups have broken links or don't specifically state which bulb/socket they used. Plus, I'm currently only able to do my computing on a smartphone so an extensive google search would be rather tedious.
Who here has the set up I'm looking for and can tell me what they've used? Also, any issues with the bulbs getting too hot and affecting the plastic housing? I doubt this would happen with LEDs but I want to double check.
Thanks.
whip is offline   Reply With Quote
Old 08-22-2014, 02:03 PM   #2
KungFuWaffle
KungFuWaffle's Avatar
Drives: Whiteout
For a dual filament use a 7443 or possibly 3157?
KungFuWaffle is offline   Reply With Quote
Old 08-22-2014, 02:36 PM   #3
WhiteFRS69
WhiteFRS69's Avatar
Drives: 2014 Scion FRS
http://www.ft86club.com/forums/showthread.php?t=10816
just use one bulb instead of two????
Old 08-23-2014, 12:41 AM   #4
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
I may have a spare almost-plug-and-play setup. I'd be able to supply everything needed. I'm doing a few local installs.
Old 08-23-2014, 01:55 AM   #5
whip
Drives: 2014 FRS MT
Great thanks for the feedback. Will be getting this done in the next few days now.
Boredom, if you have spare parts Lemmie know, I might buy them off you.
Old 09-04-2014, 02:44 AM   #6
boredom.is.me
Custom User Title
Still havent gotten around to installing the sets I have...
Socket Set MrMista Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 10-28-2013 03:21 PM
1/2" drive spline lug socket? ubersoph Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 10-07-2013 03:49 PM
02 Sensor Socket Size? swift996 Engine, Exhaust, Transmission 6 08-19-2013 09:30 PM
Socket set and torque wrench Ty89m Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 10 07-29-2013 12:46 AM
Can't torque my lug nuts socket too shallow :( chenshuo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 27 07-25-2013 10:25 AM
