Old 03-08-2020, 01:45 AM   #1
golemslord
Drives: 2014 White FRS
Socket won't fit aftermarket lug well
Hi so I got some new aftermarket wheels and used my stock lugnuts. Problem is that the 3/4 wrench and 19mm socket does not fit the lug well of the wheel? It barely fits and is basically unable to turn. Any solutions to this??
Does a thin wall socket fix this issue and also is there a thin walled lug wrench?
Thank you very much
golemslord is offline   Reply With Quote
Old 03-08-2020, 04:45 AM   #2
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Unlikely if the socket isnt fitting.
Might be time to get aftermarket lug nuts, which often use 17mm or spline/other designs that are a bit narrower
EndlessAzure is offline   Reply With Quote
Old 03-08-2020, 05:08 AM   #3
golemslord
Any recommendations on spline lugnuts that won't break the bank? Preferably black. Thanks
Old 03-08-2020, 05:50 AM   #4
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
If you need something quick till you buy some nice ones go to any auto parts store. You'll find something
Old 03-08-2020, 03:16 PM   #5
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Gorilla
I LIKE TIRES!
Old 03-08-2020, 04:42 PM   #6
ls1ac
ls1ac's Avatar
If you are using Harbor Freight they are thick walled. Snap-On is thin. They need to be thicker to be as strong.
Old 03-08-2020, 05:40 PM   #7
86MLR
86MLR's Avatar
Auto parts or ebay
20 steel nuts in various styles from $40.
Don't buy cheap alloy.
Or, spend lots because meh....drunk consuming on Ebay, the Project Mu stop the wheel from falling off
Old 03-08-2020, 06:50 PM   #8
soundman98
ProCrastinationConsultant
soundman98's Avatar
you seriously want to go cheap on the ONE thing that will keep the wheels on the car?!?
i will point and laugh.
[ame]https://www.youtube.com/watch?v=IhI3DJdjSYQ[/ame]
Old 03-08-2020, 06:53 PM   #9
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
I mean gorilla lug nuts work well and dont break the bank.
Factory lug nuts are like 2.50 per, so... they seem to work fine and are inexpensive.
Old 03-09-2020, 10:11 AM   #10
scotto79
Drives: 2016 Ablaze FRS
Stock lugs don't seat properly on aftermarket wheels. The angle part is a ball style and not a 60 degree. I had a shop mount my wheels when I first got tires mounted and thats what they did. The wheels would shift as the lug was digging into the lug holes. Ended up stripping 5 studs and breaking 2 studs off when changing back to winters on stock rims.
scotto79 is offline   Reply With Quote
Old 03-09-2020, 12:01 PM   #11
Leonardo
Country Boy 4 Life
Leonardo's Avatar
What? OEM are conical.
I LIKE TIRES!
Old 03-09-2020, 12:37 PM   #12
churchx
churchx's Avatar
Drives: 2014 GT86
As Leonardo wrote, OEM for twins are conical seat 60deg taper, which often referred as "tuner style lugnuts" (which is nice thing, as most aftermarket wheels have such kind of lugnut seat).
So if there for whatever reason ball seat lugnuts appeared in, exactly because aftermarket, not stock, wheels. IIRC ball style was common for VAG cars stock wheels.
Old 03-09-2020, 12:40 PM   #13
scotto79
Thats what I was told, that OEM was a different seat that 60 deg conicals. Thinking about it for a minute now, and the stocks were probably just too large to fit all the way down to the bottom of the aftermarket wheels.
Old 03-09-2020, 01:39 PM   #14
Leonardo
Country Boy 4 Life
Leonardo's Avatar
So, let me see if I am understanding what you are saying. Your wheel's lug nut holes are small and probably require tuner style lug nuts. Meaning the diameter of the OEM lug nut was too large to fit all the way down the hole in the wheel. So, when the lug nut felt tight, it was actually just binding with the walls of the hole not the seat.
If I understand you correctly... WOW! Thhat would be a huge problem! Glad you are OK!
I LIKE TIRES!
OEM Rear Fog Light Socket Slade Electronics | Audio | NAV | Infotainment 4 09-12-2019 02:02 PM
Wheel saver socket Ashikabi Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 02-28-2016 04:46 PM
Which LED bulb/socket? whip DIY (Do-It-Yourself) Guides 5 09-04-2014 02:44 AM
Socket Set MrMista Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 10-28-2013 03:21 PM
Socket set and torque wrench Ty89m Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 10 07-29-2013 12:46 AM
