Drives:
Manual transmission fluid flush vs drain and fill
There are two ways to service manual transmission fluid.
The first is to use a transmission fluid exchanger machine to flush the fluid. This is themore expensive of the two options. The second is to drain the fluid and then add in new fluid. Does it make a difference which method you use to maintain the warranty? |
No
Geo Tyrebighter Esq
Drives: '13 scion fr-s
The warranty expires before the first recommended trans or diff fluid change?
"I gotta rock." -- Charley Brown |
Same as engine oil, drain it when it's hot.
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
The Dictater
Drives: '13 Red Scion FRS
Just pull the fill plug first.
| The Following User Says Thank You to Spuds For This Useful Post: | 86MLR (05-26-2019) |
Drives: 2019 BRZ
Just drain and fill. “Flushing” only makes sense in automatic transmissions, where to replace the fluid, it needs to be running. But our manual transmissions are an empty case with spinny dudes in it that when at operating temp, drain to the bottom of the pan fairly quickly.
| The Following User Says Thank You to R32Gaijin For This Useful Post: | jcw99 (05-26-2019) |
Drives: 2015 BRZ
| Manual Transmission + Differential Drain Bolt Crush Washers | skylinekin | Transmission and Driveline | 0 | 12-27-2017 04:22 PM |
| Any UOA for manual transmission fluid? | qqzj | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 19 | 09-05-2017 11:41 AM |
| Is it necessary to completely flush automatic transmission fluid? | lupindub | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 4 | 05-30-2016 02:47 PM |
| Manual Transmission Fluid, GL-3 vs. GL-4 | ducky106 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 7 | 11-10-2015 06:40 PM |
| Transmission fill and drain plugs | goshem | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 5 | 07-27-2014 12:37 AM |
