Old 07-26-2014, 10:55 AM   #1
goshem
goshem's Avatar
Drives: 16' WRX
Transmission fill and drain plugs
Does any one know the parts # for both the fill and drain bolts of the transmission? When I was swapping transmission fluid I accidentally stripped mine a bit so I want to get new ones. I know that the drain plug is magnetic but I'm assuming the fill plug isn't and is different. Where can I buy them?
goshem is offline   Reply With Quote
Old 07-26-2014, 12:21 PM   #2
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Here are the Subaru part numbers...
MT fill plug: 17007AA060
MT drain plug: 17007AA070
Gasket/washer: 17008AA050 (same for fill and drain)
You're welcome
Fizz is offline   Reply With Quote
Old 07-26-2014, 02:23 PM   #3
goshem
goshem's Avatar
Drives: 16' WRX
You're welcome
thanks a bunch!
Do I just order it from the dealer?
Old 07-26-2014, 02:33 PM   #4
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Originally Posted by goshem View Post
thanks a bunch!
That or Subaru parts online..
Old 07-27-2014, 12:26 AM   #5
humfrz
thanks a bunch!
You might consider putting a bit of gasket seal on the new plugs when you put them in ..... just in case you buggered up the threads in the transmission.
Then check for any leaks after a few miles.
humfrz
Old 07-27-2014, 12:37 AM   #6
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Good idea. But it depends if he actually stripped the threads or just the hex head part. If it was the threads I'd actually prefer proper thread sealant like permatex or loctite 507.
Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve? tracerit Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 01-04-2016 07:36 PM
Factory Transmission Oil Fill - UOA R2 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 04-14-2014 01:50 PM
First fill-up... mit_peid Scion FR-S / Toyota 86 GT86 General Forum 3 01-20-2013 05:46 PM
>>>Oil Change?<<< We have you covered. Oil --- Filters --- Drain Plugs FT-86 SpeedFactory Mechanical Maintenance and Tools 7 11-14-2012 10:56 AM
MT fill and drain washers diirk Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 10 11-09-2012 12:24 AM
