Old 05-29-2016, 08:03 PM   #1
lupindub
Drives: Scion FR-S
Is it necessary to completely flush automatic transmission fluid?
So I just read the shop guide on how to change ATF on our cars and it's a bit of a pain in the ass. So is it possible to simply drain once, then fill up however much you took out without drain/overfilling 3 times? I am planning on changing the ATF every other oil change if that counts as anything. Is this a viable option or will it eventually ruin my tranny?
Basically what I want to do is ONE drain and ONE fill, aprox. every 15,000 miles and wondering if the frequency of the change can compensate for the FULL transmission flush like the manual recommends?
lupindub is offline   Reply With Quote
Old 05-30-2016, 12:50 AM   #2
humfrz
Well, now @lupindub, that would be like changing the crankcase oil a couple of quarts at a time.
I reckon a "limited change" would be better than no change at all.
However, putting in some new fluid, mixed with the old fluid just doesn't seem to the best way to go .... to me, at least.
That would be like changing your underwear by turning it inside out .....
I would suggest that if you are going to change the ATF, do it like the manual suggests .....
humfrz
Old 05-30-2016, 03:24 AM   #3
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
It doesn't, as it's "lifetime" fill.
Doing drain and fills every so often is just fine and should save you from having to eventually go to a transmission shop to have it flushed (with a machine).
Be sure to get the service manual and do the level adjustment properly or you will have shifting issues.
Old 05-30-2016, 08:15 AM   #4
Nope not the AT. Replace at 60K miles:
fumanchu1 (05-30-2016)
Old 05-30-2016, 02:47 PM   #5
humfrz
Well now, @Wayno ..... maybe that's what it says in the manual for your Australian 86, but the manual for my (US) 2013 FR-S recommends to change the ATF every 60,000 miles (like @Tcoat 's manual says).
Maybe you were thinking of the coolant .. ??
As far as changing a little bit of the ATF at a time .... why half ass the fluid change ......
humfrz
Automatic Transmission Fluid Cooler. ?? connor_lol Engine, Exhaust, Transmission 177 01-02-2023 09:02 AM
Automatic Transmission Fluid Change jmaryt Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 169 08-26-2018 07:55 PM
AUTOMATIC TRANSMISSION FLUID? How many L ScionFR-S Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 02-21-2015 12:43 AM
Brake Fluid Flush protpibe Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 01-02-2014 02:19 PM
Brake fluid flush - need some help THEWAKLER Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 11-06-2013 10:13 PM
