Old 01-11-2019, 08:59 PM   #1
fiveoneoh
Drives: none
Forester XT oil cooler questions
Has anyone who tracks the car regularly (2-3 times or more per month) used the Forrester oil cooler from this thread
https://www.ft86club.com/forums/showthread.php?t=50427
and actually logged your oil temps? I'm curious to see how well this thing works during track driving?
Any suggestions for a different oil cooler set up? I am particularly attracted to this one because of it's low cost, so it'd be nice to see some data or at least hear about your experience.
fiveoneoh is offline   Reply With Quote
Old 01-11-2019, 10:17 PM   #2
fatoni
While I haven't, I'm not sure anyone who has will tell you that's okay if you're tracking with that frequency.
Drive upgrades. Don't buy them.
Old 01-12-2019, 12:23 AM   #3
Vesartis
Vesartis's Avatar
Drives: 2016 Subaru BRZ Series.HyperBlue
I connected to the throttle body with my installation, but it's the same cooler. I posted some before and after data in this thread. http://www.ft86club.com/forums/showthread.php?p=3166393
Direct Imgur link: https://imgur.com/a/e90ChVU
Basically you can expect maybe 10-15F cooler oil temps at best. For me that was better than nothing for a car being tracked every few months, and still under warranty. With your track day frequency, you probably just want to spring for a heavier duty cooler. I will probably go Jackson Racing Dual Radiator/Oil Cooler in the future.
Vesartis is offline   Reply With Quote
Old 01-12-2019, 03:40 AM   #4
ayau
Drives: Some rust bucket
A dedicated air to oil cooler will always be better for track driving, but you'll have to inspect your oil cooler lines every so often to make sure there are no leaks. That may or may not be a hassle for you. I'm also leaning towards the OEM water cooler due to the lower risk even if that means I have to shorten my session times.
Old 01-12-2019, 04:15 AM   #5
86MLR
86MLR's Avatar
Air to oil coolers can be problematic for street duties.
Getting your oil temp up can take along time, if at all.
Thermostats are definitely required.
I fabricated up a blanking plate for 1 car I had with a air to oil cooler, without it, during the winter, my oil never got over 80°C.
As for if the Forester heat exchanger is up to the task, you need to watch/log your oil temp.
I use one, mainly to initially bring up my oil temps from cold.
Mine is plumbed into the throttle body.
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
The Following User Says Thank You to 86MLR For This Useful Post:
JIM THEO (01-12-2019)
Old 01-12-2019, 05:54 AM   #6
JIM THEO
Drives: BRZ 2018
I do believe for spirited road driving or mild track use even for places with high summer ambient temps like where I live OEM oil cooler is more than enough and better choice than an air to oil cooler.
Cost simplicity safety!
JIM THEO is offline   Reply With Quote
The Following User Says Thank You to JIM THEO For This Useful Post:
sroby (02-07-2019)
Old 01-12-2019, 02:42 PM   #7
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
My data is also in the thread Vesartis linked (my install thread):
http://www.ft86club.com/forums/showp...2&postcount=17
For me, during hard lapping, the OEM cooler made little to no difference on the track. I do like it for the street and DD as it gets the oil temps up to operating temp during the cold seasons.
For tracking 2-3 times a month like you want, I would definitely go with an air to oil cooler. But, then you have other issues to deal with like 86MLR said, not a big deal though.
justinco is offline   Reply With Quote
Old 01-12-2019, 06:35 PM   #8
treedodger
treedodger's Avatar
Drives: 2022 GR86 (was 2013 BRZ)
More data on Forester OEM cooler:
https://www.pointmeby.com/2016/09/18...z-frs-gt86-86/
As said above, if you are tracking regularly, you want an quality air/oil cooler.
2022 GR86 / 2013 BRZ
86drivechallenge.com/
treedodger is offline   Reply With Quote
Old 01-12-2019, 07:06 PM   #9
GrandSport
GrandSport's Avatar
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
No experience, just reading this thread- but I've been around motorsports for a while. Powertrain cooling is a bad place to save money- probably second only to brakes.
2014 BRZ: WRL Build (GP2) MCS, AP, Motec, race wiring harness, blah blah blah
2014 FRS: Similar WRL Build. Back up / parts / practice race car.
2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc.
1999 NB Spec Miata: 1.8 w/ all the goodies.
2022 CT5 Blackwing: Stock.
GrandSport is offline   Reply With Quote
Old 01-12-2019, 07:26 PM   #10
86MLR
86MLR's Avatar
You need data.
Until then you have no idea if the Forester heat exhanger will work, or, if not, what size air to oil cooler is required.
Have a read
Disclaimer: this is only the first thing that came up googling.
Not alot of people actually get the sizing right.
https://www.pegasusautoracing.com/do...ocID=TECH00133
Old 01-12-2019, 11:24 PM   #11
jflogerzi
jflogerzi's Avatar
For regular track use you will want a decent air to air oil cooler. The OEM cooler is more for getting oil temps up to temp quicker in colder climates. For street and and back road driving it can help. Most who have done testing show a 10-15F lower temps but your milage will vary. I plan to run my OEM oil cooler using the throttle body method at the track in next 30 to 60 days with 5w-30 oil. I plan to run 4-5 hpde per year and will skip summer months.
2013 Series 10 FRS #553
Old 01-13-2019, 03:36 AM   #12
JIM THEO
Drives: BRZ 2018
Originally Posted by 86MLR View Post
You need data.
Have a read
I wonder what oil flow restriction induces the OEM oil cooler?
Cause there is some restriction even from it so has someone logged oil pressures before and after fitting it?
Old 01-14-2019, 08:59 PM   #13
dpaqu
Drives: 2018 Gt86
Good question. It might get bypassed if its on the oil filter housing. I know GM put spring loaded bypasses to avoid people exploding there oil filters on cold days.
dpaqu is offline   Reply With Quote
Old 01-15-2019, 01:17 AM   #14
86MLR
86MLR's Avatar
I believe they are for blocked filters from lack of maintenance.
RToyo86 (05-09-2020)
OEM Oil cooler from the 2.0 DIT Forester Kostamojen Engine, Exhaust, Transmission 119 09-10-2019 05:28 AM
FS: Oil Cooler - Forester XT Setup kamikaze7 Canada Classifieds 4 08-21-2016 09:15 AM
NED Forester OEM oil cooler kit ryoma Engine, Exhaust, Transmission 2 04-20-2015 07:16 PM
FS: used forester oem diy oil cooler cruizin01 Engine, Exhaust, Bolt-Ons 2 01-05-2015 04:12 AM
