Old 09-16-2013, 03:10 PM   #1
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
OEM Oil cooler from the 2.0 DIT Forester
So I popped the hood on a Forester XT with the 2.0DIT boxer engine at the dealer today and the first thing I noticed was the factory oil cooler...
Anyone care to test one of these out on a Twin?
Kostamojen is offline   Reply With Quote
Old 09-16-2013, 03:16 PM   #2
wootwoot
Drives: FRS
This has been discussed several times. The consensus seems to be that it is an oil warmer more than an oil cooler. That is, it helps the oil get to operating temperature in cold climates. The exchanger is so small that it wouldn't cool the oil very effectively, even for a daily driver.
wootwoot is offline   Reply With Quote
Old 09-16-2013, 03:28 PM   #3
jamesm
the heat exchanger is the easy part. this could still be a win for someone looking for a cusco-like watercooled setup for less $$$. that is, of course, if it's less $$$.
Old 09-16-2013, 04:20 PM   #4
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Drives: Vortech Prototype Test Car
This makes no sense. Cylinder walls warm oil. Nothing with fins warms !
Does the gizmo run coolant thru it?
448hpsti is offline   Reply With Quote
Old 09-16-2013, 06:10 PM   #5
xwd
it does run coolant through it. This is the same oil cooler you will find on 02-07? WRXs. Cusco actually re-packaged the OEM part as an oil cooler for the BRZ... I wouldn't waste your time on it.
Old 09-16-2013, 06:33 PM   #6
Calum
That Guy
Drives: 2013 asphalt FRS MT
If we could locate an inline liquid to liquid heat exchanger this would seem to be decent solution. But alas, my climate really doesn't call for one.
Old 09-16-2013, 06:36 PM   #7
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Wasn't gonna waste time , rather you confirmed suspicions, that's why I asked about the coolant,thanks ya learn something daily
Thanks @dwx
Old 09-16-2013, 06:39 PM   #8
xjohnx
Grip>Slip
xjohnx's Avatar
i think i saw someone on here use a mocal laminova like that.
Old 09-16-2013, 06:42 PM   #9
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Or just run a robispec oil water radiator?
Old 09-16-2013, 06:49 PM   #10
zoomzoomers
zoomzoomers's Avatar
Drives: 2013 Subaru SWP BRZ Limited 6AT
I think the jury's still out on this type of setup. We're not "just" talking about saving some money here. We're also talking about decreasing the complexity of the setup. If this type of cooling system were to work, even decently, then it along with a larger capacity radiator could just do the trick. All without having to add a physical oil cooler and the hardware to go with it.
Personally, I'm keeping my eyes on this and see where it can go. A member has already purchased the Cusco package and should have some results, and hard data, for us soon.
IIRC, @tonystewart
Man Law#17:A man in the company of a hot, seductively dressed, woman MUST remain sober enough to fight!
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam.
zoomzoomers is offline   Reply With Quote
Old 09-16-2013, 07:07 PM   #11
Calum
That Guy
While I agree that is by far the most eloquent solution. I still don't know what I'm going to end up using for a power adder, so I don't want to buy into something and then find out I don't have the room for it.
Old 09-17-2013, 03:23 AM   #12
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
I wouldn't underestimate a simple, oem cooler like this, if you track your car. Even though engine coolant is hot, its not the 270+ f oil temps people are seeing on track. Now the other advantage is probably no loss in oil pressure and no exposed oil lines.
I was going to run an STi OEM oil cooler before trying anything else as oil pressure is of paramount importance on a boosted FA20.
I have a very serious radiator on our STi race car and an 8 quart dry sump setuo but I rely only on the oem oil cooler FWIW.
Element Tuning is offline   Reply With Quote
Old 09-17-2013, 08:13 AM   #13
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Nice find. Maybe this would be a good solution to use with a koyo radiator. I like the robispec setup but I don't like how it adds a ton of weight (wet weight) way up front and I can't just remove my bumper beam to compensate.
industrial is offline   Reply With Quote
Old 09-17-2013, 10:01 AM   #14
Kostamojen
Ya, these have been on EJ motors for what, 20 years now?
I ran one on my N/A impreza for like 6 years. Its certainly not going to hurt anything. Especially if coolant tempts are around 190 and people really are hitting 270 for oil temps!!! That 80 degree difference certainly means this kind of air/water-cooled oil cooler will have an effect in extreme situations.
The ECU doesn't read oil temps right?
BRZ wheels on Forester XT sea otter 99 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 01-02-2017 06:56 PM
Wheel Directory: OEM Subaru Forester STi (2005) 18x7.5 +48 Surok Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 03-24-2015 07:42 PM
2014 Forester key fob - nicer than BRZ Turbowned Cosmetic Modification (Interior/Exterior/Lighting) 3 04-17-2013 03:35 PM
OEM Forester All Weather floormats Laika Cosmetic Modification (Interior/Exterior/Lighting) 2 01-14-2013 09:19 PM
1998 Forester on BRZ/FRS Rims :) Meeners BRZ Photos, Videos, Wallpapers, Gallery Forum 11 11-23-2012 08:45 PM
