Old 10-31-2013, 05:54 PM   #1
CARNZ
CHECK ENGINE
Drives: 2004 STi
Post Installed/How-To: 2014 Forester XT OEM Oil Cooler(pics!)
After talking in the Oil Cooler discussion thread about the OEM FXT oil cooler I ordered the parts to get the ball rolling on this.
I ordered almost all of the FXT oil cooler components except for one hard line(bolts to the driver side valve cover, links oil cooler hose to bottom water pipe).
Here's what you will need:
OEM PARTS:
  • 21311AA170 - OIL COOLER, COMPLETE
  • 14050AA970 OR 14050AB090 - PIPE, WATER
  • 21328AA220 - PIPE, OIL COOLER
  • 99078AB330 - HOSE, WATER
  • 21317AA070 - CONNECTOR, OIL COOLER
  • 805918010(x3) - HOSE, CLAMP
  • 808206010(x2) - BOLT 6x12x12
  • 092315002(x2) - HOSE, CLAMP
  • 1-2 Gallons of Subaru Super Blue Coolant
Miscellaneous:
Initially I ordered most of the parts and laid them out to see what all I had:
The small hoses, one big clamp, 2 bolts, and 2 small clamps were not needed. Don't worry they are not listed above.
1.Start by removing your airbox and oil filter(you will not need to drain the engine oil for this install.)
2. Remove the 24mm union that the oil filter screws on to and set the oil cooler in it's place and thread in the oil cooler connector - 21317AA070. Don't tighten it down yet, just hand screw it in.
3. Install the feed water hose(faces passenger side of engine), Hose (99078AB330) with 2 hose clamps (805918010).
4. Bolt the oil cooler pipe(21328AA220) to the front chain cover of the engine using the 2 purchased bolts (808206010).
Picture is for step 3 and 4
5. Lift/jack up the car and use a 6mm allen socket to remove the water block off plug from the upper oil pan. Be careful as some coolant will come out of this passage.
6. Install a M14x1.5 plug with a 1/2 hose barbed end into the hole exposed from removing the plug in step 5. This is where you will need the ~8 inches of 1/2 inch water hose and one hose clamp of your choice.
7. Connect your water hose in step 6 to the bottom of the oil cooler pipe you installed in step 4. Use one hose clamp (805918010) to secure the hose to the oil cooler pipe.
8. Pull the water hose off the black water pipe seen in the upper right corner of this picture. Also remove the bolt that secures the pipe to the cylinder head. Don't lose the bolt as this is re-used.
9. Follow the water pipe to the back of the cylinder head and remove the two hoses connected to it along with the bolt that secures it to the head. You can now remove the water pipe.
10. As you can see there ARE some differences between the FXT(14050AA970) and BRZ water pipes(aside from the provision for the oil cooler hose). Once the FXT pipe is bolted onto the BRZ head you can see the heater hose provision on the back is bent towards the car, compared to facing straight-up on the BRZ.
11. You can get the BRZ heater hose on the FXT(14050AA970) pipe. You will need to use a little bit of muscle and slightly angle the hose differently so it goes on and doesn't kink shut. I have a very slight kink in mine but it doesn't hinder flow and i have full heater function. You will notice the FXT pipe is taller where the smaller coolant hose goes on, I installed the smaller coolant hose as far as I could get it on to the pipe and have zero leaks.
12. Take your 18 inches of 3/8 heater hose and install it on to the drain side of the oil cooler. (Driver side port of cooler) It will be a close fit to the injector crash shield on the intake manifold but it will fit with zero kinks. Install one hose clamp (092315002) to secure the hose to the cooler. Tighten the 24mm oil cooler connector bolt now, I can't remember the exact torque spec (it's around 50 ft-lbs)
13. Route this hose down the side of the valve cover along the wire harness for exhaust AVCS. I used one zip-tie to hold the hose in one place with the harness. Cut the hose to the needed length and attach it to the FXT water pipe using hose clamp (092315002).
14. Re-install airbox and burp your cooling system.
Enjoy your OEM oil cooler! This looks completely factory and functions very well.
I noticed the oil temps got to operating temperature quicker and stabilized once the engine was hot.
I recommend Heuberger Subaru's Online Parts store as your source to get the Oil Cooler Parts, see screenshot below.
Enjoy,
Mike
i don't cry about crickets
CARNZ is offline   Reply With Quote
The Following 131 Users Say Thank You to CARNZ For This Useful Post:
2013GTRNate (05-13-2014), 2_slo (01-16-2014), aaguirre123 (06-05-2014), AceHeader-MT (11-26-2013), acro (05-04-2014), akidnamedguiza (09-18-2016), akyp (10-31-2013), alexand3r (10-31-2013), amram (03-26-2014), andrewFT86 (10-31-2013), Anthonytpt (11-14-2013), autobrz (11-14-2013), bgibbsunc (01-28-2014), Bimble Bamble (02-17-2015), brybot (11-15-2017), BRZ68 (10-31-2013), Brzzee (12-01-2013), Calum (03-12-2014), chanomatik (10-31-2013), charged86 (12-12-2013), Chenslee (10-14-2015), CxG (04-25-2016), DandoX (11-02-2017), DJCarbine (11-01-2013), DocWalt (10-23-2015), Eurasianman (05-20-2014), Fareast auto part (03-31-2015), FearBoy (10-31-2013), finch1750 (10-31-2013), flippy (08-21-2014), FRSBRZGT86FAN (02-19-2015), fstlane (05-24-2014), glamcem (03-21-2014), Grambi (04-07-2015), Grip Ronin (11-12-2013), Guff (11-07-2013), Guillaume (02-15-2014), Gums (10-31-2013), G_Ride (11-08-2013), hamzam (04-22-2014), Hanakuso (11-02-2013), hyper4mance (05-14-2014), ill86 (11-04-2013), illmatic (10-31-2013), indy (12-06-2015), jamesm (11-02-2013), jcw99 (01-17-2015), jdmblood (12-01-2014), jeebus (11-02-2013), JMon85 (10-31-2017), Joeyk (05-03-2016), juliog (11-23-2015), Kakawate (11-04-2013), keen as (11-04-2013), LeeMaster (11-03-2013), LucidMomentum (03-30-2015), M1K3 (10-31-2013), Malt (11-12-2013), MannyO (01-12-2014), mid_life_crisis (11-01-2013), Mikem53 (11-02-2013), mit_peid (05-02-2014), MJones_RB (05-19-2015), MmmHamSandwich (09-18-2014), MoarGeesPlease (03-02-2015), Mr. (11-01-2013), muffinz (09-10-2014), mweidner311 (05-02-2014), nalc (11-01-2013), Ozzman (10-31-2013), P@ul (11-03-2013), paiceyfan (05-10-2017), Paiser (07-17-2015), PantsDants (10-31-2013), PineappleFriedRice (11-08-2013), pmccut (10-31-2013), post_break (11-20-2013), PStaff716 (11-03-2013), R2 (10-31-2013), Rampage (11-08-2013), Ramster (03-13-2015), RazBRZ (11-14-2013), ripper (09-14-2014), roddy (11-01-2013), rs999 (09-08-2014), Rx FR-S (04-13-2021), s2d4 (10-31-2013), sato (11-21-2014), ScionFR-J (02-06-2014), Scooby South (11-14-2013), Seattle944t (01-10-2014), sickmint79 (04-09-2015), SirBrass (05-02-2014), SkAsphalt (02-08-2016), skye67 (02-15-2015), Slammedsteve (08-04-2015), Slartibartfast (04-11-2014), spdfreak (03-31-2015), SportInjected (10-31-2013), stevesnj (05-02-2015), suaveflooder (10-31-2013), T-Steve (10-15-2016), taiguy (01-27-2017), Tatsu333 (12-03-2024), TeamZleep (11-01-2013), Teseo (01-31-2018), The Slow One (12-10-2013), TIE Pilot (11-04-2013), tigermack (01-05-2015), TofuJoe (09-18-2016), Trac Toy (11-03-2013), Trap63 (11-18-2013), Tye300 (11-01-2013), u/Josh (11-03-2013), VerusEric (03-18-2016), WatchmaN (03-07-2014), Weasel Soup (01-21-2015), weederr33 (12-28-2016), Wepeel (11-03-2013), whataboutbob (11-01-2013), WillRacer1jz (02-22-2015), WRB-DZA-BRZ (11-13-2013), wulfstan (04-19-2015), Xero-Limit (10-31-2013), xkalelx (08-10-2015), xn7485 (11-28-2013), xxscaxx (11-01-2013), ysr50guy (10-31-2013), zkv476 (10-28-2014), zoomzoomers (11-04-2013), zoth (03-26-2014)
Old 10-31-2013, 06:07 PM   #2
SubaSteve
Captain Cocoa
Drives: CBS BRZ MT
What did this end up costing you?
SubaSteve is offline   Reply With Quote
The Following 2 Users Say Thank You to SubaSteve For This Useful Post:
Fa20sc (12-19-2013), whataboutbob (11-01-2013)
Old 10-31-2013, 06:08 PM   #3
B2FiNiTY
JDM JUNKY
B2FiNiTY's Avatar
Drives: NSX
wow, very nice write up!
B2FiNiTY is offline   Reply With Quote
Old 10-31-2013, 06:10 PM   #4
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
nice write up, but do you have any pics?
smbstyle is offline   Reply With Quote
Old 10-31-2013, 06:12 PM   #5
CARNZ
CHECK ENGINE
Drives: 2004 STi
With my employee price it was around $220 for everything I needed.
Old 10-31-2013, 07:28 PM   #6
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
Horay!!!
Why didn't you use the valve cover side hard line?
Also post a link to that fitting for the block!
Kostamojen is offline   Reply With Quote
Old 10-31-2013, 07:32 PM   #7
CARNZ
CHECK ENGINE
Drives: 2004 STi
Originally Posted by Kostamojen View Post
Horay!!!
I didn't use the V/C hard line because I felt it would interfere with the injector crash shields on the BRZ engine, since it has Port and Direct injection it's laid out a little differently than the FXT, also the DI pump is on the pass-side head on the FXT so I'm sure the routing would interfere with where our pumps are.
Old 10-31-2013, 07:43 PM   #8
Kostamojen
OK, thats what I needed to know. Thanks
Old 10-31-2013, 09:13 PM   #9
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
Oh my! If this helps the oil to warm up any quicker then I'm definitely in! Thanks for the write up!
Old 10-31-2013, 09:35 PM   #10
PantsDants
Drives: Scion FR-S A/T, Whiteout
Noob question: Do all of these instructions/parts apply to installing this on an automatic car?
PantsDants is offline   Reply With Quote
Old 10-31-2013, 09:41 PM   #11
CARNZ
CHECK ENGINE
Drives: 2004 STi
I would assume so, but I don't own an auto BRZ so not 100% sure. I wouldn't think anything that you do here would be affected by AT/MT.
The Following User Says Thank You to CARNZ For This Useful Post:
Old 10-31-2013, 10:19 PM   #12
akyp
Drives: 2012 86
I like this solution far better than Cusco's.
Now to find a shop that can do the install for me...
akyp is offline   Reply With Quote
Old 10-31-2013, 10:20 PM   #13
smbstyle
smbstyle's Avatar
So the title says "pics!" but I dont see any.... are pics showing for anyone else?
Old 10-31-2013, 10:23 PM   #14
CARNZ
CHECK ENGINE
Drives: 2004 STi
for real? lol.
if they really aren't working I will re-host them.
they work for me
brz, fxt, oil, oil cooler
OEM Oil cooler from the 2.0 DIT Forester Kostamojen Engine, Exhaust, Transmission 119 09-10-2019 06:28 AM
Bought a 2014 Subaru Forester EAGLE5 Other Vehicles & General Automotive Discussions 10 10-02-2013 01:54 PM
2014 Forester key fob - nicer than BRZ Turbowned Cosmetic Modification (Interior/Exterior/Lighting) 3 04-17-2013 04:35 PM
BRZ 2.0L Turbo in 2014 Forester Sleeperz BRZ First-Gen (2012+) — General Topics 37 03-21-2013 07:42 PM
Review after test driving a 2013 WRB BRZ and 2014 Forester in Okinawa, Japan… 2013GTRNate BRZ First-Gen (2012+) — General Topics 12 02-01-2013 01:29 PM
