NED Forester OEM oil cooler kit
Is anyone that is using this kit have any problems with leaking from the coolant line going into the throttle body loop? I just installed my kit today and the lines were too big for the throttle body nipples, but I just got some worm clamps and tightened it as far as I could go. however, there is still a little bit of play at the connection. I'm assuming since the coolant going through it isn't super high pressure that there shouldn't be any problems with leaking, but I just wanted to confirm. I observed it while burping my coolant and there were no obvious leaks. Hopefully it stays that way.
Drives: RX-7 / BRZ
Use some adjustible radiator hose clamps. like this. https://www.2wheelpartssupply.com/sa...FRAwaQod7oIA5g
also you can get reducers from 1/2 to 3/8 and such to get her down to the correct size, don't forget additional clamps. All this is super easy to find at your local autoparts store. IIRC plastic or metal reduces are only around $2 or so...
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
Drives: Toyota 86 GTS
If you get some good clamps, they will still chew up the hose but you'll be able to get it to not leak.
| OEM Oil cooler from the 2.0 DIT Forester | Kostamojen | Engine, Exhaust, Transmission | 119 | 09-10-2019 05:28 AM |
| BNIB Forester 2.0 X.T oil Cooler Kit - SoCal | SG02WRX | Engine, Exhaust, Bolt-Ons | 11 | 04-15-2015 07:45 PM |
| FS: used forester oem diy oil cooler | cruizin01 | Engine, Exhaust, Bolt-Ons | 2 | 01-05-2015 04:12 AM |
| Houston, TX - Complete Forester XT OEM Oil Cooler | The Slow One | Engine, Exhaust, Bolt-Ons | 4 | 06-19-2014 07:28 PM |
| <FS> Forester XT oil cooler setup $250 shipped | mav1178 | Engine, Exhaust, Bolt-Ons | 4 | 03-07-2014 06:45 PM |
