Old 01-09-2019, 02:35 AM   #1
mkodama
86 Challenge
Drives: 2017 BRZ
Sold - FS: Forester oil-to-water cooler setup
Sold
$170 shipped
Everything you need for the Forester oil-to-water heat exchanger setup. Faster oil warm-up AND improved cooling when it gets too hot. This makes a noticeable difference, but doesn't have the capacity for track days at 100F+ ambient temperatures. Perfect for street or autocross setups though and looks OEM when installed. Parts were used for about 5000 miles and have no wear or damage.
-Forester heat exchanger
-Forester hard lines
-Forester coolant hoses
-Optional modified BRZ coolant hose with stainless T-fitting that can be used in place of Forester hard lines.
-All non-standard hoses for routing coolant
-Hose clamps
-Aluminum barbed fitting to replace water pump plug
mkodama is offline   Reply With Quote
Old 01-09-2019, 07:23 AM   #2
jslack
Drives: 2017 Red subaru BRZ Limited
You think this would work great for timed road challenge in the middle of the summer in the midwest? Won't ever be drifting or running track stuff
jslack is offline   Reply With Quote
Old 01-10-2019, 02:34 AM   #3
speed3n_86
Drives: FRS
PMd
speed3n_86 is offline   Reply With Quote
Old 01-10-2019, 03:17 AM   #4
mkodama
86 Challenge
Drives: 2017 BRZ
I’ve never done a timed road challenge so I can’t say for sure. I’ve used this in 100F weather on Thunderhill Raceway and 90F weather on Laguna Seca and it allows me to get to the end of a 15-20 minute session at 260-270F oil temp, while without I’m at those temperatures about 10 minutes in.
Originally Posted by speed3n_86 View Post
PMd
Replied.
Old 01-11-2019, 10:15 AM   #5
majixmatrix
BRZ Wannabee
majixmatrix's Avatar
Drives: 2013 Limited BRZ
Will this work with the AT?
majixmatrix is offline   Reply With Quote
Old 01-11-2019, 02:56 PM   #6
mkodama
86 Challenge
Drives: 2017 BRZ
I’m not sure. Probably depends on how you route it. I’ve read but not confirmed the AT cars use the blocked off forester port for the transmission? But if you route the coolant with the throttle body heater method I don’t see why not.
Old 01-13-2019, 03:21 AM   #7
majixmatrix
BRZ Wannabee
I think I'm just gonna wait until I can find a used Jackson Racing radiator with oil cooler! Thanks!! Glws
Old 01-14-2019, 02:53 PM   #8
pjp
Drives: frs
Cooler
Do you still have it for sale
Thanks paul
pjp is offline   Reply With Quote
Old 01-14-2019, 07:42 PM   #9
mkodama
86 Challenge
Drives: 2017 BRZ
Thanks paul
Yep, still available.
Old 01-15-2019, 09:52 AM   #10
pjp
Drives: frs
Do you have the instructions for install or is it obvious?
Old 01-15-2019, 11:08 AM   #11
mkodama
86 Challenge
Drives: 2017 BRZ
Either of these methods would work. I would give the first method with the throttle body loop a try; you don’t even need to jack up the car. I did the method more similar to the forester and it’s kind of a pain.
https://www.ft86club.com/forums/showthread.php?t=73684
https://www.ft86club.com/forums/showthread.php?t=50427
Old 01-15-2019, 09:45 PM   #12
pjp
Drives: frs
I can do $140
Old 01-19-2019, 07:37 PM   #13
jflogerzi
jflogerzi's Avatar
Bump. Good deal for a daily driver and canyon Carver. The TB install is much easier to install and has been proven to be just as effective as the old install.
2013 Series 10 FRS #553
OEM Oil cooler from the 2.0 DIT Forester Kostamojen Engine, Exhaust, Transmission 119 09-10-2019 05:28 AM
FS: Oil Cooler - Forester XT Setup kamikaze7 Canada Classifieds 4 08-21-2016 09:15 AM
NED Forester OEM oil cooler kit ryoma Engine, Exhaust, Transmission 2 04-20-2015 07:16 PM
FS: used forester oem diy oil cooler cruizin01 Engine, Exhaust, Bolt-Ons 2 01-05-2015 04:12 AM
<FS> Forester XT oil cooler setup $250 shipped mav1178 Engine, Exhaust, Bolt-Ons 4 03-07-2014 06:45 PM
