Old 09-07-2014, 03:32 AM   #1
The Sentinel
Project BRZ-Boosted Autos
The Sentinel's Avatar
Drives: MY14 BRZ
VIDEO - Install guide for OEM style coolant loop Oil cooler.
Here is a full install guide for a sandwich plate style Oil Cooler like what's found in the MY13+ Forester XT and MY15 WRX...
Purchased from www.forgedperformance.com.au
For full videos for Pre and Post install temperature and performance analysis Click Here
[ame="https://www.youtube.com/watch?v=21qWLjhRlfY"]Project BRZ - Video 21 - Oil Cooler Install Guide (Forged Performance Australia) - YouTube[/ame]
Check out my ProjectBRZ YouTube Channel and Facebook Page for the latest reviews, guides and information.
The Sentinel is offline   Reply With Quote
The Following 4 Users Say Thank You to The Sentinel For This Useful Post:
Fizz (09-07-2014), GhostOp86 (04-18-2015), hmong337 (09-07-2014), mit_peid (03-07-2015)
Old 09-07-2014, 06:27 AM   #2
Anorexic 86
Trim the Fat & add Boost
Anorexic 86's Avatar
Drives: sometimes I fly
So this is an alternative way to connect the hoses compared to another DIY?
http://www.ft86club.com/forums/showthread.php?t=50427
Anorexic 86 is offline   Reply With Quote
Old 09-07-2014, 09:45 AM   #3
The Sentinel
Drives: MY14 BRZ
Correct. Although in this case, you purchase the cooler as a kit, with all the parts and hoses required to connect to the locations I've used in the video.
The Following User Says Thank You to The Sentinel For This Useful Post:
charged86 (09-10-2014)
Old 09-07-2014, 09:46 AM   #4
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Did you drain the coolant for the install? If not, how much coolant comes out when you disconnect the loop hose? Gushing out or just a small flow?
Fizz is offline   Reply With Quote
Old 09-07-2014, 11:35 AM   #5
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Great video! Subbed for reference. Thanks.
hmong337 is offline   Reply With Quote
Old 09-07-2014, 11:45 AM   #6
WhiteFRS69
WhiteFRS69's Avatar
Drives: 2014 Scion FRS
really??? $450
when watching this video, i was expecting it to be around the 100-200 dollars range...
The Following User Says Thank You to WhiteFRS69 For This Useful Post:
IBill4You (04-17-2015)
Old 09-07-2014, 06:46 PM   #7
The Sentinel
Drives: MY14 BRZ
No need to drain the coolant.
Depends how quickly you do it. The bottom hole doesn't flow at all, but the top hole continues to flow until you put the hose on.
You lose whatever is in loop pipe, plus whatever comes out before you get the next pipe on.
Just be careful it doesn't come out of the pipe an in to the throttle body.
Old 09-07-2014, 06:46 PM   #8
The Sentinel
Drives: MY14 BRZ
Originally Posted by WhiteFRS69 View Post
really??? $450
Car stuff is a LOT more expensive here in Australia.
Old 09-07-2014, 06:55 PM   #9
s2d4
s2d4's Avatar
The cooler is $135 USD, delivered to Australia would be max 180 AUD, add the hoses and clamps at best $200 AUD.
He needs to make money, but $450 is way too high for me.
The Following User Says Thank You to s2d4 For This Useful Post:
WhiteFRS69 (09-07-2014)
Old 09-07-2014, 08:51 PM   #10
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
When connecting the hoses to the TB, does it matter which hose goes to the top and which goes to the bottom?
Old 09-08-2014, 08:14 AM   #11
Guillaume
Guillaume's Avatar
Drives: Exige S 240
Do you get the same kind of mass flow in the cooler as with the Forester-like set-up?
Old 09-08-2014, 08:41 AM   #12
d1ck
Drives: Black 2013 FRS
Why didn't you burp the air from the coolant system?
d1ck is offline   Reply With Quote
Old 09-08-2014, 12:34 PM   #13
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
I was wondering about that as well. There must be a good reason why Subaru chose to route the oil cooler that way as opposed to the simpler TB option.
Old 09-09-2014, 12:12 AM   #14
The Sentinel
Drives: MY14 BRZ
I would imagine so. It's also the same setup that's used on the MY15 WRX. although they use different locations for the oil feed on the WRX.
forged performance, oem, oil, oil cooler, temp
Real-time Oil temperature Analysis - Pre/Post Coolant Loop Oil Cooler Install The Sentinel Engine, Exhaust, Transmission 92 03-09-2015 05:20 PM
Install guide for Cusco Dif Brace? empower-auto Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 12-01-2014 05:11 PM
Is there a guide to install oem armrest? Frs32907 Cosmetic Modification (Interior/Exterior/Lighting) 3 04-11-2014 11:06 PM
DIY 6000K HID Kit Installation(Scion FR-S ONLY) - Video Guide Alex DIY (Do-It-Yourself) Guides 10 07-09-2013 07:38 AM
Seat belt guide install BRZranger BRZ First-Gen (2012+) — General Topics 28 06-09-2012 09:51 PM
