Old 09-06-2018, 04:59 PM   #1
...My Nine Rides Shotgun
Drives: 2016 Scion FR-S RS 2.0
Pinch weld damage and repair
Hey,
So recently, I ran my car over a curb and bent the pinch weld pretty badly. I've seen people straighten them with pliers or whatever, but I would guess bending it with pliers would only weaken the metal further. What do I need to do to make it a reliable jacking/support point again? Do I need to buy the sheet metal and get someone to weld it in? I've looked around the net, and it seems that pliers are the most popular answer, but no one comments on the reliability of the jacking points afterward.
...My Nine Rides Shotgun is offline   Reply With Quote
Old 09-06-2018, 05:11 PM   #2
Originally Posted by ...My Nine Rides Shotgun View Post
Hey,
Where exactly is the bend? Just how bad is it bent?
Those saying just use pliers are probably correct. As long as you didn't deform the rocker panel the weld should be just fine bending it back. Make sure you cover any flaked or cracked paint though or it could be a nasty rust spot.
EndlessAzure (09-06-2018)
Old 09-06-2018, 05:16 PM   #3
Leonardo
Country Boy 4 Life
Leonardo's Avatar
In the past this has happened to a car I owned. I just jack the car up from a different position.
My FR-S has side skirts that hide a small dent on the lower edge near the pinch weld. It is what it is. I would avoid throwing money at it, since it does not change the way the car drives.
I LIKE TIRES!
The Following 2 Users Say Thank You to Leonardo For This Useful Post:
Icecreamtruk (09-06-2018), Strife26 (09-06-2018)
Old 09-06-2018, 07:04 PM   #4
Thaeyo
Thaeyo's Avatar
I was researching the same thing, It's only worth fixing if there's absolutely no other points you can jack up the car like the LSD, etc.
Thaeyo is offline   Reply With Quote
Old 09-06-2018, 07:20 PM   #5
It's at the rear right pinch weld. I had it on a lift yesterday. From what I could see, the rocker and floor pan weren't damaged. Just the side skirt and pinch weld.
Old 09-06-2018, 07:25 PM   #6
Just bend it back and touch up the paint. All will be fine.
Old 09-06-2018, 07:38 PM   #7
Cool. Thanks for the insight, everyone!
Pinch weld side of the car bending! Mikeez Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 22 10-22-2015 10:48 PM
Pinch weld jack point paint damage? Ingen Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 37 10-12-2015 09:43 AM
Jack Stands + Pinch Weld Wyattkb Scion FR-S / Toyota 86 GT86 General Forum 36 10-12-2015 04:45 AM
Someone backed in to me (damage and repair pics inside) JBrochacho Scion FR-S / Toyota 86 GT86 General Forum 20 04-16-2014 05:11 AM
protecting the pinch weld lifting points midnitz Scion FR-S / Toyota 86 GT86 General Forum 1 02-08-2013 10:36 PM
