Old 01-14-2013, 08:09 AM   #1
Ingen
Drives: Ultramarine FR-S 6MT
Pinch weld jack point paint damage?
So I jacked my car up this weekend to do the usual tire-swapping work, starting at the front and then moving to the back. I picked up some jack stand pads, thinking they would protect the finish.
Turns out no.
The pinch weld cut down in to the pad, and the pad material A) kind of scraped away at some of the paint, causing some to flake off and B) caused the layers of metal to separate slightly at one corner, kind of peeling apart. When I took the jack stands out the stupid pads were stuck to the car :@
Anyway, how should I go about touching up an area like this? I figured I would clean it with dawn dish soap, wipe down with alcohol, and then apply... something.
Any ideas?
Car Received: 10/18. Break in ended: 10/28
Goal: Openflash UEL headers, Stage II 93 oct, TRD intake, arm rest :P
Ingen is offline   Reply With Quote
Old 01-14-2013, 08:45 AM   #2
Noob4Life
86 Noob
Drives: Firestorm FR-S
I believe they make a rubberized under body paint in a rattle can. Or you can just go with the regular primer/paint setup.
Noob4Life is offline   Reply With Quote
Old 01-14-2013, 09:08 AM   #3
Ingen
Yeah, sort of what I figured.
Should I try to flatten it all back out?
Old 01-14-2013, 09:12 AM   #4
Noob4Life
86 Noob
Did you bend the pinch weld? I was under the impressions you just scrapped the paint off.
Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
Old 01-14-2013, 10:28 AM   #5
Ingen
I bent one layer I think? It sort of turned up a layer of metal like a book page (slightly though, it didn't even bend all the way to the weld).
I will take a pic this afternoon to illustrate what I'm talking about. Describing it is difficult
Old 01-14-2013, 10:49 AM   #6
DarkSunrise
DarkSunrise's Avatar
That happened to me before on a past car. The previous owner must have jacked the car up from that side to do his oil changes. If it bothers you, you can use vice clamps to straighten the pinch weld back out, then coat it with underbody spray. May want to think about using a pinch weld adapter of some sort.
I fixed mine because the factory jack wouldn't work with the bent pinch weld.
2022 BRZ Build
2013 FR-S Build
Old 01-14-2013, 03:18 PM   #7
BMWDavid
Drives: '89 911, '06 GTI, '13 BRZ
I use hockey pucks. They are harder and will not cut. So far on my BRZ no damage to the pinch weld or the paint.
2005 Honda XR650L
1989 Porsche Carrera 3.2 Coupe
2006 VW GTI/DSG
2013 Subaru BRZ WRB Limited 6MT-gone but not forgotten
2014 Nissan Murano SV
BMWDavid is offline   Reply With Quote
Old 01-14-2013, 03:46 PM   #8
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Get one of these:
http://www.purems.com/Products/PROTE...-Lift-Jack-Pad
Old 01-14-2013, 03:52 PM   #9
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
Originally Posted by ATL BRZ View Post
Those look great but are so spendy. It's just a chunk of poly, after all.
cobrabyte is offline   Reply With Quote
Old 01-14-2013, 04:13 PM   #10
Hanakuso
I'm not sure how you guys are installing hockey pucks on a jack stands. Anyone have a link to a DIY? I've only seen how to do it for jacks
Hanakuso is offline   Reply With Quote
Old 01-14-2013, 04:49 PM   #11
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Lift it from the front subframe and rear diff instead...pinch weld damage is always bound to occur.
Rayme is offline   Reply With Quote
Old 01-14-2013, 08:37 PM   #12
Ingen
Of course got a floor jack just for this but I hate the idea of working supported only by the jack. So I put the stands on and this jazz happens.
Old 01-14-2013, 08:52 PM   #13
Miniata
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
For swapping wheels/tires, I never use jack stands, because I'm never under the car. Just a floor jack with a hockey puck (with a slit cut in it) to protect the pinch weld, and I lift one side of the car at a time. Works great, no damage to the pinch weld or paint.
When I do need to use jack stands, I have some poly jack stand pad protectors that I believe are made by Prothane, that I bought at Summit. They do not get cut by the pinch weld when supporting the weight of the car, even on much heavier cars like my Mustang.
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar
Miniata is offline   Reply With Quote
Old 01-15-2013, 10:18 AM   #14
Ingen
I may end up using this method and just using the front and back jack points to quickly swap the tires. Seems like the best alternative, and honestly I spend more time farting around with jack stands than I do changing the tires!
Does Vinyl Wrap Damage Paint? GhostofAkina Cosmetic Modification (Interior/Exterior/Lighting) 8 01-09-2013 01:54 AM
What is the point of this car? dem00n Scion FR-S / Toyota 86 GT86 General Forum 88 10-09-2012 03:31 AM
Minor paint damage Double4Free Great Lakes 8 07-23-2012 07:35 PM
BRZ at Point Mugu, CA ashtray BRZ Photos, Videos, Wallpapers, Gallery Forum 5 07-01-2012 06:52 PM
All it needed was some JB Weld... 82mm 4g63 Other Vehicles & General Automotive Discussions 2 09-15-2011 08:12 PM
