Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
Drives: 2016 Scion FR-S RS 2.0
Pinch weld damage and repair
Hey,
So recently, I ran my car over a curb and bent the pinch weld pretty badly. I've seen people straighten them with pliers or whatever, but I would guess bending it with pliers would only weaken the metal further. What do I need to do to make it a reliable jacking/support point again? Do I need to buy the sheet metal and get someone to weld it in? I've looked around the net, and it seems that pliers are the most popular answer, but no one comments on the reliability of the jacking points afterward. |
#2 | |
Those saying just use pliers are probably correct. As long as you didn't deform the rocker panel the weld should be just fine bending it back. Make sure you cover any flaked or cracked paint though or it could be a nasty rust spot.
The Following User Says Thank You to Tcoat For This Useful Post: | EndlessAzure (09-06-2018) |
#3 |
Country Boy 4 Life
In the past this has happened to a car I owned. I just jack the car up from a different position.
My FR-S has side skirts that hide a small dent on the lower edge near the pinch weld. It is what it is. I would avoid throwing money at it, since it does not change the way the car drives.
I LIKE TIRES! |
The Following 2 Users Say Thank You to Leonardo For This Useful Post: | Icecreamtruk (09-06-2018), Strife26 (09-06-2018) |
#4 |
I was researching the same thing, It's only worth fixing if there's absolutely no other points you can jack up the car like the LSD, etc.
#5 | |
#6 |
Just bend it back and touch up the paint. All will be fine.
#7 |
Cool. Thanks for the insight, everyone!
Pinch weld side of the car bending! | Mikeez | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 22 | 10-22-2015 09:48 PM |
Pinch weld jack point paint damage? | Ingen | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 37 | 10-12-2015 08:43 AM |
Jack Stands + Pinch Weld | Wyattkb | Scion FR-S / Toyota 86 GT86 General Forum | 36 | 10-12-2015 03:45 AM |
Someone backed in to me (damage and repair pics inside) | JBrochacho | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 04-16-2014 04:11 AM |
protecting the pinch weld lifting points | midnitz | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 02-08-2013 09:36 PM |
