Old 10-12-2015, 08:34 PM   #1
Mikeez
Engineering Student
Drives: Scion FR-S 2015
Pinch weld side of the car bending!
So I lift my car to change to my winter tire, and I noticed that everytime I raise the car with my floor jack... it bends the pinch welds on the side of the car... I can't put my jack in the front on the car (car too low for fat lift)
what am I doing wrong? Why is it bending...
Once I lift the car, I put jack stands and the stands don't bend...
There’s no time to stop for gas, we’re already late
Mikeez is offline   Reply With Quote
Old 10-12-2015, 08:48 PM   #2
Mikeez
Engineering Student
My garage is in cement and its not fully leveled, might that be the cause?
Old 10-12-2015, 09:01 PM   #3
eggncheese
Drives: 2013 Ultramarine Scion FRS MT
Mine is bent too if it makes you feel any better. Anyone know of an effective way to bend it back?
eggncheese is offline   Reply With Quote
Old 10-12-2015, 09:46 PM   #4
vroom4
Just start using a piece of wood on the inside edge of that weld to lift car and don't worry about it.
Also, if car is too low to lift from front, drive up on said pieces of wood to get the jack under the front subframe. Then put jack stands, with Hf rubber covers, along inside edge of that pinch weld.
vroom4 is offline   Reply With Quote
Old 10-12-2015, 09:49 PM   #5
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Old 10-12-2015, 10:30 PM   #6
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Dude.
Buy some 2x4's or 4x6's two foot lenghts and have the store cut them at a 25 degree angle up to one foot or till equal.
Do not be afraid of bending the pinch welds. If it bothers you that much get some pliers and bend them back. The only reason why the car has pinch welds are for the factory jack to stay put.
You'll be fine using your jack with no problems. Just a bending pinch weld. No big deal. It's just cosmetic.
Old 10-12-2015, 10:35 PM   #7
vroom4
Well the front fender bolts to the front one I think....so you don't want to completely flatten it.
Old 10-12-2015, 10:58 PM   #8
Mikeez
Engineering Student
Alright guys =p... Thanks for all the inputs I just want to say I read all of your posts.
Old 10-13-2015, 12:13 AM   #9
DAEMANO
Time Traveller
Originally Posted by Kiske View Post
Flyin' Miata Jack Adapter $19.95
https://www.flyinmiata.com/fm-jack-adapter.html
Old 10-13-2015, 03:47 PM   #10
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Hockey puck Haggard style lol
Old 10-13-2015, 10:52 PM   #11
mrk1
Drives: Sterling BRZ Ltd
Second the hockey puck, use them all the time
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 10-14-2015, 09:05 AM   #12
slim blanco
slim blanco's Avatar
Drives: 2017 86
i cut up an old, barely used tire i had lying around. one pad each for 4 stands and a larger pad for the jack, works great.
if your car is too low to get the jack under, get some wood and drive up on it like suggested...that's what i've been doing for ten years haha.
slim blanco is offline   Reply With Quote
Old 10-14-2015, 01:12 PM   #13
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
I have one of these:
https://www.google.com/webhp?sourcei...d+pad&tbm=shop
Old 10-14-2015, 04:56 PM   #14
8R6
8R6's Avatar
Drives: FRS
i tried using hockey pucks, slotted in the middle 3/4" and it ended up getting split apart after about 6 times of use. i tried again with another hockey puck and same exact thing.
now i use a metal one for pinch welds and it's awesome. i forgot the exact name, but it's metal, red, magnetic, and comes with a tag that says "remove before flight" or something.
8R6 is offline   Reply With Quote
Pinch weld jack point paint damage? Ingen Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 37 10-12-2015 08:43 AM
Jack Stands + Pinch Weld Wyattkb Scion FR-S / Toyota 86 GT86 General Forum 36 10-12-2015 03:45 AM
SPEEDHUNTERS: The WELD FR-S!!! Kiske Scion FR-S / Toyota 86 GT86 General Forum 44 10-27-2014 05:17 PM
protecting the pinch weld lifting points midnitz Scion FR-S / Toyota 86 GT86 General Forum 1 02-08-2013 09:36 PM
PTB or Peformance Tube Bending Exhaust Video and dyno Pekingduck Engine, Exhaust, Transmission 15 09-26-2012 02:03 AM
