Old 07-22-2018, 02:08 PM   #1
scion fr-s
scion fr-s's Avatar
Drives: 2017 PP BRZ
Tranny Fluid
This is my first time posting so bare with me! I am having trouble up shifting from first to second and down shifting from 6th to fifth gear. When i try to put it in gear i have to force it and that is no good. I currently am running the OEM Fluids. I bought Redline gear oil to see if that helps out. i will let you guys know.
scion fr-s is offline   Reply With Quote
Old 07-22-2018, 09:59 PM   #2
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
Can you give us some info on the car? Year, mileage, any modifications done (particularly anything related to your transmission), etc.
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
Old 07-22-2018, 10:37 PM   #3
humfrz
Welcome to posting, there, scion fr-s ….
Well, the new fluid may help...
Tell me you don't have a short shifter on that puppy ???
humfrz
Old 07-23-2018, 02:59 AM   #4
Lakitu
Lakitu's Avatar
Drives: 2017 Halo 86
You might have to mess around with putting the stick into multiple slots so the tranny fluid can spread all over.
Build Thread / Daily Driver
OFT Stage 2+, GrimmSpeed CAI, JDL Ultra Quiet FP, Perrin 2.5" Resonated CBE, Enkei 18x8.5 +45, 245/35 Continental ExtremeContact
Lakitu is offline   Reply With Quote
Old 07-23-2018, 03:24 AM   #5
humfrz
That makes no sense to me.
Back-in-the-day, I messed around and put my stick in multiple slots and .. and .. what the hell are YOU talking about
humfrz
Old 07-23-2018, 03:31 AM   #6
Lakitu
Lakitu's Avatar
humfrz
HAH!
Old 07-23-2018, 03:48 AM   #7
humfrz
HAH!
Isn't it waaaaaay past your beddy bye time ??…
humfrz
Old 07-23-2018, 04:05 AM   #8
Lakitu
Lakitu's Avatar
Correct. fml...
Old 07-23-2018, 06:41 AM   #9
CoolHandMoss
Drives: 2013 FRS
I didn't like the way my FR-S shifted much either. I tried Redline and was not impressed with it in that car as I usually am in most cars. I found that AMSOIL worked with that transmission much better. Also, make sure you're using an OEM or other weighted shift knob and swapping the shifter bushing for a stiffer one helps too.
CoolHandMoss is offline   Reply With Quote
Old 07-24-2018, 12:46 PM   #10
scion fr-s
scion fr-s's Avatar
Drives: 2017 PP BRZ
2014 frs with 54k miles. I just recently replaced the clutch with an Exedy oem clutch. I have exhaust and a intake. Nothing done to the tranny.
Old 07-24-2018, 12:50 PM   #11
scion fr-s
scion fr-s's Avatar
Drives: 2017 PP BRZ
humfrz
Thank you... I am hoping the fluid will help and no i do not have a short shifter. It is the stock shifter that came with the car.
Old 07-24-2018, 01:00 PM   #12
scion fr-s
scion fr-s's Avatar
Drives: 2017 PP BRZ
I heard good reviews about AMSOIL. i do not think you can buy AMSOIL online. Correct me if i am wrong. That is why i went with REDLINE. If i can buy AMSOIL online that will be my second choice of fluids if i am not satisfied with REDLINE. i have the stock shifter and stock oem knob. I did some searching on the forums and people upgrade the shifter bushing. Im considering it.
Old 07-24-2018, 01:13 PM   #13
humfrz
Did your car shift poorly before you replaced the clutch?
humfrz
Found this while changing my tranny fluid Dipstik-sportech Engine, Exhaust, Transmission 25 12-28-2022 04:08 PM
Auto Tranny/Diff Fluid Change Christopher86 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 7 12-27-2017 05:53 PM
Have you changed your tranny fluid of your AUTO BRZ/FRS ScionFR-S Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 01-14-2017 01:14 AM
Tranny fluid or engine oil leak? G.I.Choe Issues | Warranty | Recalls / TSB 1 05-28-2014 06:53 AM
tranny fluid change Dispect Engine, Exhaust, Transmission 3 01-27-2013 11:31 AM
