Old 08-26-2013, 02:34 PM   #1
Dipstik-sportech
Dipstik-sportech's Avatar
Found this while changing my tranny fluid
So I was changing my fluid to day and found this ball stuck to the drain plug. It's not a shift ball, they're both there I checked. It does feel funny shifting into fourth like it just falls in no click nothing. Anyone have any ideas?!
Old 08-26-2013, 03:01 PM   #2
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
what da heck!!!
Old 08-26-2013, 03:06 PM   #3
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
ummm
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 08-26-2013, 03:15 PM   #4
2superblus
2superblus's Avatar
Drives: 13 BRZ WRB
You may have a faulty trans bearing inside.
2superblus is offline   Reply With Quote
Old 08-26-2013, 03:22 PM   #5
SkullWorks
Drives: SSM LT MT BRZ
I would stop now and take it to Subaru.
unless you have an aftermarket clutch...
SkullWorks is offline   Reply With Quote
Old 08-26-2013, 03:26 PM   #6
Dipstik-sportech
I have an aftermarket everything lol. Trans sounds no different than normal. Not saying something isn't messed up but I might tear te tranny apart this weekend and need to know where to look
Old 08-26-2013, 06:35 PM   #7
Dipstik-sportech
Well it's coming out and apart this weekend. Does anyone know where to find an exploded diagram or An fsm for this transmission?
Old 08-26-2013, 08:25 PM   #8
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
@Art_Mighty's Avatar
Drives: Asphalt AVO FR-S w/a Slushbox! :P
If you search someone posted an .iso file for the complete 2013 BRZ dealer manual. You'll find what you're looking inside.
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn
@Art_Mighty is offline   Reply With Quote
Old 08-26-2013, 08:45 PM   #9
charged86
charged86's Avatar
Omg
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 08-26-2013, 09:34 PM   #10
suaveflooder
whaaaaaaa?!
suaveflooder is offline   Reply With Quote
Old 08-26-2013, 09:47 PM   #11
whataboutbob
AutoX-10/10ths every run
Probably not good. Please let us know what you find out.
Build thread:Here
Old 08-26-2013, 09:53 PM   #12
SkullWorks
I would suspect all bearings and shift detent locations for the shifter mechanism.
you mentioned it went in to fourth with less resistance does it also come out more easily, like slide out too easily while accelerating in fourth?
Old 08-26-2013, 09:54 PM   #13
SkullWorks
shit I guess i could have peeked at your signature before i posted eh?!
Old 08-26-2013, 10:01 PM   #14
Dipstik-sportech
We're thinking it's one of the balls from the no.4 transmission clutch hub the synchronizer key spring ball. Could this be the cause of all the grinding trannys?!
Using higher quality brake fluid vs using cheap but changing more often ayau Tracking / Autocross / HPDE / Drifting 41 06-14-2015 01:20 PM
How do I check the tranny oil? mashal Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 08-18-2014 03:03 PM
tranny fluid change Dispect Engine, Exhaust, Transmission 3 01-27-2013 11:31 AM
Is the auto tranny from a isf? WolfsFang Engine, Exhaust, Transmission 6 08-25-2012 09:25 PM
MT vs AT tranny... better MPG, 0-60? subatoy BRZ First-Gen (2012+) — General Topics 163 03-26-2012 06:08 PM
