Old 05-28-2014, 12:55 AM   #1
G.I.Choe
Drives: 2013 Scion FRS Argento
Tranny fluid or engine oil leak?
I recently discovered this on my parking spot (it's a condo parking lot with assigned spots), and started freaking out. I don't have jack stands or ramps, so I can't get under there.
Luckily I'm still on my factory warranty.
Backstory on this car: had my fuel pump replaced in late 2013, my tranny replaced January 2014, and my rear axle tightened last week. I've kept up with the free oil changes and services, and now I've run into this little gem.
The dipstick looks good, and the fluid on it is a different color than what I'm seeing on the ground. It's tranny fluid right? Just want to get a consensus...
http://imgur.com/yUtGEzD,aspMzMn#0
G.I.Choe is offline   Reply With Quote
Old 05-28-2014, 06:53 AM   #2
roddy
roddy's Avatar
Drives: '13 Ultramarine
Have a look at this thread. This is the first place I would look, and it is easy to check from the top.
http://www.ft86club.com/forums/showthread.php?t=26197
Also, you should be able to reach under the car and feel around the drain plug. If a new gasket wasn't used at the last oil change, or the plug wasn't tightened enough to completely crush the gasket, you could have a slight leak there as well. Another thing to note: when the oil pan is painted, the drain plug and gasket are in place. This makes it fairly difficult to remove the gasket at the 1st oil change. If the tech/person doing the oil change doesn't notice this, you could end up with 2 gaskets in place on the drain plug. This could also result in a bit of a leak. Engine oil always looks darker on the ground than it does on the dipstick.
Found this while changing my tranny fluid Dipstik-sportech Engine, Exhaust, Transmission 25 12-28-2022 04:08 PM
part number and spec for genuine BRZ tranny fluid? imom Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 0 03-28-2014 05:02 AM
FINALLY engine is broken in...engine/tranny smell? denverizzles Engine, Exhaust, Transmission 18 09-15-2013 08:12 PM
Brake fluid leak.. tintumz22 Issues | Warranty | Recalls / TSB 9 02-01-2013 03:20 PM
tranny fluid change Dispect Engine, Exhaust, Transmission 3 01-27-2013 11:31 AM
