Old 01-26-2013, 03:55 PM   #1
Dispect
Newbie Car Enthusiast
Dispect's Avatar
Drives: Asphalt 6MT FR-S
tranny fluid change
hi guys. ive seen alot of people claim that some fluid called "pentoil" or something really helps improve the shifting from 1st to 2nd. the only problem i have is- how do i change the fluid? i dont wanna bring it to a shop where they charge me an arm and a leg. thanks guys
Dispect is offline   Reply With Quote
Old 01-26-2013, 04:03 PM   #2
nostromo
nostromo's Avatar
Do it your self. There is a tutorial on here with pics. Took me all of 1\2 hr to do it. Most of your time is spent getting the car on Jack stands.
Sent From My Note II Using The Space-Time Continuum
nostromo is offline   Reply With Quote
Old 01-26-2013, 05:19 PM   #3
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
I believe the Tranny fluid you want is Pentosin 75w80. check the DIY section
FreshFRS is offline   Reply With Quote
Old 01-27-2013, 11:31 AM   #4
A5D5TRYR
A5D5TRYR's Avatar
Drives: FR-S 6MT Ultramarine (BeeDrill)
The only real pain in the ass about changing the trans fluid is the brush guard removal and getting the new fluid in without making a mess. The fill plug is high enough that there's no way you can just pour oil into a funnel so you need to use a hand pump to pump the oil in. The one I had sucked and ended up taking forever and made a mess. Get yourself a good one and it likely won't be so bad.
2013 Scion FR-S - Ultramarine 6MT
A5D5TRYR is offline   Reply With Quote
Automatic Transmission Fluid Change jmaryt Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 169 08-26-2018 07:55 PM
Transmission and Differential Fluid Change LINK Amadeus DIY (Do-It-Yourself) Guides 1 12-23-2012 06:01 PM
MT fluid change experience Brzer Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 12-16-2012 02:25 AM
Fluid change siXXtoes Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 12-06-2012 09:39 AM
500 Mile - Complete fluid change Touge Factory Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 42 11-07-2012 04:10 PM
