Old 02-07-2015, 01:36 PM   #1
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
Have you changed your tranny fluid of your AUTO BRZ/FRS
If you changed your fluid please tell me how you did it and what fluid you used... Can't seem to find anyone who has done it yet but I'm hearing it's complicated ... Im bringing it to prime motoring but I wanna hear form experience who has done it so I can help them out and give them feedback
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
ScionFR-S is offline   Reply With Quote
Old 02-26-2015, 06:07 PM   #2
ScionFR-S
ScionFR-S's Avatar
Bump that shit
Old 02-26-2015, 06:41 PM   #3
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
bump...in for info too!
Old 02-26-2015, 07:25 PM   #4
Fastbrz
Drives: Wrb brz
I would go to Procom Racing
Fastbrz is offline   Reply With Quote
Old 02-28-2015, 02:24 PM   #5
ScionFR-S
ScionFR-S's Avatar
a little too far for me about 2 hours away... AZP seems to know their stuff i might go to them ... great price with fluid also and labor
Old 02-28-2015, 03:34 PM   #6
Estey
Drives: Scion FR-S, Ultramarine
pm @Sithspawn
he is really knowledgeable on the subject. Im pretty sure he knows whats involved in changing the fluid.
Ive been meaning to change my fluid as well, but havent had a chance to buy the fluid or look at the service manual.
From what Ive heard, its fairly straightforward. The most difficult thing that i foresee is checking fluid temps, but I believe there is a way to determine whether or not you are in range.
Estey is offline   Reply With Quote
Old 03-07-2015, 12:55 AM   #7
sixthree
Drives: 14BRZ
Whats the recommended km interval to change the transmission fluid?
sixthree is offline   Reply With Quote
Old 03-07-2015, 01:31 AM   #8
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
60,000 miles or 60 months. It's supposed to be inspected every 30,000 miles.
N1rve
Old 03-09-2015, 11:35 PM   #9
nlowell
nlowell's Avatar
Drives: 2013 Scion FRS
Essentially it's add 2 quarts, shift gears, bring to temperature, let out fluid, add 2 quarts, shift gears, bring to temperature, let out fluid,add 2 quarts, shift gears, bring to temperature, let out fluid...
On the last time (at the right temperature) open the bottom drain until the fluid coming out is hair thin. Close and torque.
To do it "right" you have to activate the mode where the temperature is shown on the dashboard using the shift lights. In order to trigger this mode you have to use a Toyota trans diag tool or I think I read somewhere you can put in a jumper (wire) between two pins on the transmission diagnostics plug.....or you just guess on the temperature....
B: REPLACEMENT
1) Lift up the vehicle and maintain in a horizontal position.[*1]
2) Remove engine under cover No. 1.
3) Remove engine under cover No. 2.
4) Remove the drain plug and gasket, and drain the fluid.[*2] \
5) Temporarily tighten the drain plug using a new gasket.[*3]
NOTE:
R eplace the gasket and perform final tightening according procedures [*16].
6) Remove the refill plug (A) and O-ring.[*4]
7) Remove the overflow plug (B) using a socket hexagon wrench.[*5]
8) Add fluid through the refill hole until the fluid flows out of the overflow tube.[*6]
CAUTION:
• Useauto-fluidWS.
• Slowly add the fluid. Adding the fluid rapidly can cause the fluid to hit internal parts and splash around resulting in fluid flowing out of the refill hole.
9) Wait until the fluid stops flowing and is only dripping.[*7]
10) Temporarily tighten the overflow plug using a 5-mm (0.2 in) socket hexagon wrench and a new gasket.[*8]
11) Add fluid through the refill hole until reaching the specified amount when removing/installing the oil pan.[*9]
NOTE:
If fluid flows out from the refill hole and you cannot fill the specified amount when adding fluid through the refill hole, perform procedures [*10] to [*15] below in order to circulate fluid until it reaches the oil passages in the transmission and inside the torque converter, then add the specified amount of fluid through the refill hole.
Filling amount (reference): 2.0 L (2.1 US qt, 1.8 Imp qt)
12) Temporarily tighten the refill plug using an O-ring.[*10] 13) Lower the vehicle.[*11]
14) Start the engine.[*12]
NOTE:
Start the engine with the air conditioning turned off.
15) Slowly move the shift lever from the P to M position, and shift again to the P position.[*13] 16) Idle the engine for 30 seconds to warm up the engine.[*14]
17) Turn the key to IG OFF.[*15]
18) Repeat procedures from [*1] to [*15].
19) Repeat procedures from [*1] to [*2].
20) Perform final tightening of the drain plug using a new gasket.
Tightening torque:
20 N·m (2.1 kgf-m, 7.4 ft-lb)
21) Repeat procedures from [*4] to [*11].
22) Adjust the fluid amount. <Ref. to PM-72, AUTOMATIC TRANSMISSION FLUID AMOUNT ADJUST- MENT, ADJUSTMENT, Automatic Transmission Fluid.>
23) Install engine under cover No. 2.
24) Install engine under cover No. 1.
25) Lower the vehicle.
26) Procedures finished.
nlowell is offline   Reply With Quote
Old 03-10-2015, 12:30 AM   #10
phrosty
Sounds confusing, not looking forward to it.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 03-10-2015, 12:44 AM   #11
nlowell
nlowell's Avatar
The way they wrote the instructions is confusing if you ask me but the process is pretty straight forward...just time consuming. You have to keep the fluid at the right temperature and sometimes this means letting the car/fluid cool - not to mention using a lift to lower the car, run it, shift, raise the car, drain and fill, lower the car....
You get my point I think
Old 03-10-2015, 06:06 PM   #12
Estey
all this lifting and lowering seems like such a headache without a lift
Thanks for the info though!
Old 03-13-2015, 01:50 AM   #13
Li Zhang
Drives: BRZ Series.Blue White
Those instructions are like Tech Data... Straight boring... I can't believe the people who wrong those instructions.
I guess I did my fluid change wrong. I just drained the Diff and Trans and filled it back up never changed gears.
Remove fill plug
Remove drain plug, let it drain
Install drain plug
Fill Fluid, once fluid starts to come out of the Fill plug let it drip/even out completely and leveled then install plug.
I'll tell ya boy did I see a lot of metal on my magnet.
Li Zhang is offline   Reply With Quote
Old 12-19-2016, 11:05 PM   #14
aminninja
aminninja's Avatar
Drives: gt86
this need youtube how to video
aminninja is offline   Reply With Quote
Found this while changing my tranny fluid Dipstik-sportech Engine, Exhaust, Transmission 25 12-28-2022 04:08 PM
WARNING: If you changed your transmission fluid, please read MrBodyMassage Engine, Exhaust, Transmission 47 05-09-2015 12:09 AM
Tranny fluid or engine oil leak? G.I.Choe Issues | Warranty | Recalls / TSB 1 05-28-2014 06:53 AM
part number and spec for genuine BRZ tranny fluid? imom Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 0 03-28-2014 05:02 AM
tranny fluid change Dispect Engine, Exhaust, Transmission 3 01-27-2013 11:31 AM
