Old 06-26-2018, 05:39 PM   #1
Turbo
Drives: FR-S Turbo
OEM oil temp sensor location and accuracy ?
I noticed the ECU has an oil temp sensor feed in the OBD2 data, and I'm trying to find where this temp is being measured?
Is it the sensor I circled in yellow in the attached picture?
And does anybody know how accurate the OE sensor is? I'm asking because I'm seeing about a 10 degree F differential between the OE sensor in the OBD2 data and the GlowShift oil temp gauge that's installed, which has me scratching my head a bit. The GlowShift sensor in my car is mounted in a port on my Skunk2 Racing oil cooler sandwich plate.
(Original pic from the GlowShift gauges WEBsite. It shows their oil sensor adapter installed, as well as an example of where to install the sender unit for their temp gauge which I circled in red. In my case, this sensor is mounted in the oil cooler sandwich plate)
Turbo is offline   Reply With Quote
Old 06-26-2018, 05:43 PM   #2
The OEM temp sensor is accurate.
Old 06-26-2018, 06:22 PM   #3
Turbo
Drives: FR-S Turbo
Thanks, Mike. Is it the sensor I circled in yellow ?
The label "temp sensor" in that diagram is actually pointing to the GlowShift sensor that feeds their gauge.
Old 08-12-2024, 04:24 AM   #4
qiumaoyuan
qiumaoyuan's Avatar
Drives: 2017 BRZ MT, 2009 Civic sedan AT
No, that one is coolant temperature sensor.
qiumaoyuan is offline   Reply With Quote
Old 08-12-2024, 11:55 AM   #5
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Correction: That is the oil temp sensor. The coolant temp sensor is under the manifold. Can OP post a picture of the location of the Glowshift sensor?
Old 08-16-2024, 03:16 PM   #6
Grady
Grady's Avatar
I would trust the OEM sensor. Your sensor is not installed in the oil flow.
Old 08-19-2024, 04:54 PM   #7
GrandSport
GrandSport's Avatar
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
They're just reading at two different points. No big deal.
I have a display off my OBD2 in my track only BRZ. It's fine.
2014 BRZ: WRL Build (GP2) MCS, AP, Motec, race wiring harness, blah blah blah
2014 FRS: Similar WRL Build. Back up / parts / practice race car.
2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc.
1999 NB Spec Miata: 1.8 w/ all the goodies.
2022 CT5 Blackwing: Stock.
GrandSport is offline   Reply With Quote
Oil Temperature Sensor Location g0odspeed DIY (Do-It-Yourself) Guides 4 01-30-2018 10:03 AM
Water temp gauge location evo13 Electronics | Audio | NAV | Infotainment 0 02-11-2016 03:00 AM
Sandwich plate - oil temp reading "accuracy" 1Cor10:23 Engine, Exhaust, Transmission 3 04-08-2015 01:36 AM
Eng coolant temp sensor location D K Engine, Exhaust, Transmission 28 08-27-2014 05:30 PM
OEM Oil Temp Sensor Location Khorne Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 01-15-2014 10:38 PM
