Old 02-11-2016, 03:00 AM   #1
evo13
Drives: frs
Water temp gauge location
Hi I'm not sure if this is consider to be asking in this section but I'm trying to install water temp gauge and I know there is a adapter to do it easy way but I'm just wondering if there is a spot that I can just put the sensor in with out buying the adapter. I did with oil temp and pressure gauge finding the spots and it worked. I mean I didn't do it the mechanic that I know found it but if you guys can send me a picture of the spot I would appreciate it. Thanks
evo13 is offline   Reply With Quote
FS: BNIB Prosport Guages (Water Temp / Exhaust Gas Temp) AtlasMick Interior Parts (Incl. Lighting) 2 03-31-2015 05:47 PM
Eng coolant temp sensor location D K Engine, Exhaust, Transmission 28 08-27-2014 05:30 PM
OEM Oil Temp Sensor Location Khorne Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 01-15-2014 10:38 PM
STRI DSD SLM II Gauges (boost/oil temp/oil press/water temp/egt) BNIB ziptiedae86 Interior Parts (Incl. Lighting) 0 10-29-2013 11:50 PM
A/C Oil/Water temp gauge Exhaust Scion FR-S / Toyota 86 GT86 General Forum 16 02-07-2013 01:19 PM
