Old 01-29-2018, 11:03 PM   #1
g0odspeed
Drives: 2013 Scion FR-S Asphault
Oil Temperature Sensor Location
Ok guys!! I hope this is the correct area for this, but I just gotta fill you in on this great find. I know there has been debate of where to locate this sensor and we all agree that having it in the oil pan is ultimately the best place for the most accurate reading. Then you have to tap your oil pan and have a bung welded on. We that is no longer the case. This has nothing to do with the ft86 but I found this little gem at Trail Tech. It’s geared for dirt bikes and atv’s, but this temperature sensor adapter allowed me to replace my oil plug and install the sensor. Same thread pattern as I cross referenced the M16x1.5. Below is the link to this product. And it super cheap!!!! 10 bucks plus shipping and your good to go.
Item Number: VA-16150
http://https://www.trailtech.net/oil-temp-sensor-adapter-m16x1-5
g0odspeed is offline   Reply With Quote
Old 01-29-2018, 11:25 PM   #2
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
I would be afraid of it hanging down under the car. Better to come off a oil filter sandwich plate or the main oil galley under the AC compressor I would think.
Lunatic is offline   Reply With Quote
Old 01-30-2018, 06:48 AM   #3
CoolHandMoss
Drives: 2013 FRS
Nothing wrong with mounting it there except that I'd rather keep my magnetic drain plug. I've had one there in other cars for many miles and it worked well.
CoolHandMoss is offline   Reply With Quote
Old 01-30-2018, 07:07 AM   #4
g0odspeed
Completely understandable. This doesn’t protrude beyond your skid pan, and I t stays tucked up in there. However, I’m sure there is always some possibility.
Old 01-30-2018, 10:03 AM   #5
Lunatic
Lunatic's Avatar
If it stays above the skid pan then yes it should be OK. But I would still feel better myself mounting it elsewhere.
Where is the ambient temperature sensor located? solidONE Software Tuning 10 09-17-2023 02:21 PM
Cabin temperature sensor location avg BRZ First-Gen (2012+) — General Topics 2 06-10-2017 12:06 PM
O2 Oxygen Sensor Fuse Location? Synack Engine, Exhaust, Transmission 6 04-09-2015 09:47 PM
Oil temperature sensor and cable Junkwipe Electronics | Audio | NAV | Infotainment 0 07-18-2014 10:06 AM
OEM Oil Temp Sensor Location Khorne Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 01-15-2014 10:38 PM
