Old 07-15-2017, 10:53 AM   #1
radroach
Drives: car
Crush washers OEM vs Belmetric or other
Going to do trans and diff fluid service, looked up the parts numbers on Toyota / Subaru dealership websites and they want $12 shipping for a $1 washer.
I'm hearing I could try a Belmetric washer and save money?
From: http://www.ft86club.com/forums/showt...58#post2386658
Originally Posted by PWBRZ View Post
Transmission
2 flat washers - 24mm OD x 18mm ID x 2mm (drain and fill are same size)
Belmetric: GA18X24T
Differential
2 crush washers - 24mm OD x 18mm ID x 2mm (drain and fill are same size)
Belmetric: GCA18X24
The stock washers I took off the transmission were virtually identical to the Belmetric GA18X24T.
The stock washers from the differential were similar to Belmetric GCA18X24 but not copper. To be honest, if you wanted to you could even use the same ones used for the transmission. Just make sure to use a torque wrench to get proper torque to 'crush' the washers.
Yes? How well would these hold up. Spending $2.20 vs $25 at dealership.
Old 07-15-2017, 11:59 AM   #2
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
You could go to the dealership parts counter and buy it in person. If it's a ways away, I'd suggest calling ahead to make sure they have it.
Old 07-15-2017, 04:41 PM   #3
radroach
Drives: car
@Spuds the Subaru dealership parts counter barely had a clue. When he started looking up parts for an AWD vehicle I had to stop calling there.
Old 07-15-2017, 06:39 PM   #4
dutchman1
Drives: 2017 86 6-Speed
Dowty rings.
I use these things on everything. They're designed for hydraulic fittings and will hold upwards of 10,000 psi, but seal well at low/no pressure too.
https://www.amazon.com/Swordfish-319...ds=dowty+rings
2017 86 set up for CS STX autocross
dutchman1 is offline   Reply With Quote
Old 07-16-2017, 02:39 PM   #5
Ernest72
Drives: 16 Silver BRZ, 04 Silver WRX wagon
Just go to advanced auto or auto zone and get washers for the size bolt - used them for years - no leaks, no issues.
Ernest72 is offline   Reply With Quote
Old 07-16-2017, 04:47 PM   #6
radroach
Drives: car
@Ernest72 last time I checked my local autozone didn't have any crush washers.
Old 07-24-2017, 08:45 AM   #7
Ernest72
No they just have washers - these washers are slightly softer metal and can deform making a good seal upon tightening. When you change them out you will see a little ring around the washer. Thats why you don't reuse them. Seriously no issues on multiple cars for years.
Old 07-24-2017, 01:46 PM   #8
Chronology
Drives: 13' Satin White Pearl BRZ
Originally Posted by dutchman1 View Post
Dowty rings.
This! 100%.
RS*R Sport-I w/custom spring rate / Cusco Front/Rear Sways, Cusco Diff Brace / Cusco Power Brace (Rear/Front/Upper/Lower) / JDL UEL Headers / INVIDIA Q300 Ti / Valenti Revo Tails and rear backup/ EcuTek / Moto-East Flexfuel / Moto-East E85 tune
Chronology is offline   Reply With Quote
Old 07-24-2017, 08:42 PM   #9
ryoma
ryoma's Avatar
I buy all my crush washers from Belmetric. I am not spending $10 for a transmission/diff washer from the dealership lol. it helps to buy in bulk (like 10+) so you don't get screwed over from shipping
Old 07-25-2017, 09:47 AM   #10
radroach
Drives: car
Here's the transmission and differential fill and drain crush washers GCA18X24 , GA1824T , I received from Belmetric for $2.50 w/ $8 flat rate shipping.
Old 07-29-2017, 01:56 PM   #11
four-mat
Drives: 2014 Subaru BRZ
I'll be returning my $39 set of washers I got from Toyota then
Sent from my LG-H918 using Tapatalk
four-mat is offline   Reply With Quote
Old 07-31-2017, 09:28 AM   #12
Kayysonie
Badass Member
Drives: 2014 SWP BRZ Limited
If this is your first time doing diff and tranny, you can reuse the OE washers. just give it a littler tighter than the torque spec.
Next time (2nd time changing fluids) just get new washers. Find the part number, give it to a local dealer and have them hunt it. If they say they cant find it call their manager and tell them they suck.
Kayysonie is offline   Reply With Quote
Old 07-31-2017, 09:45 AM   #13
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
SU003-03626 for the transmission drain and fill washer gasket is the same exact size as hondas transmission drain plug and it costs 2.27 instead of 11 bucks.
save some money. hondas part number is 90471-px4-000
Old 08-03-2017, 09:02 PM   #14
four-mat
I bought the over priced washers for the trans and differential. I also bought one dimple magnetic plug for trans or diff. Is it suggested to have one plug per. Drain plug or also one per fill plug?
Are the differential crush washers the same? givemeporknow Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 02-16-2020 12:16 AM
diff crush washers + AT gasket + satin white pearl touch-up paint autobrz Mechanical Maintenance and Tools 9 07-13-2016 04:40 PM
Transmission&Diff crush washers reusable? BDKane01 Issues | Warranty | Recalls / TSB 3 07-11-2016 03:33 PM
FS: 11x Subaru Oil Filters w/ Crush Washers (15208AA130) Argento_FR-S Mechanical Maintenance and Tools 2 04-01-2016 10:08 AM
Can the transmission crush washers be reused? brillo Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 11 04-15-2013 07:35 PM
