Old 04-29-2015, 05:28 AM   #1
givemeporknow
Drives: 2015 brz series.blue wr blue pearl
Are the differential crush washers the same?
For the fill and drain plug? I cannot find the fill crush washer online without having to pay $15 for the shipping but I found the drain crush washer for about $6 for two shipped my house. Anybody have any idea? I did search but could not find it online and I figured someone on here has to know...
givemeporknow is offline   Reply With Quote
Old 04-29-2015, 05:58 AM   #2
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
i dont think the differential washers are Crush washers ... (don't Need to replace)
SU00300122
http://www.scionpartswebstore.com/p/...U00300122.html
^ has diagram with the parts number plan
The Following User Says Thank You to Bonburner For This Useful Post:
givemeporknow (04-29-2015)
Old 04-29-2015, 12:29 PM   #3
givemeporknow
SU00300122
Thanks for your time but I did enough research to know that both transmission washers are just aluminum washers and that both the differential washers are crush. I also went to the website that you posted already but I do not want to pay the $15 shipping like I said. I already have all the part numbers as well. I just want to know if the differential fill and drain crush washers are the same. I know that somebody on the forum already measure them with a digital caliper and found them to be the same size but he did not mention if they were interchangeable. I was thinking that maybe they just have different part numbers or something...
Old 04-29-2015, 12:35 PM   #4
There are two different crush washers for the differential, but they can be used interchangeably.
We include both crush washers with our trans/diff maintenance packages, and all three crush washers in our full fluid change packages.
givemeporknow (04-29-2015), jcw99 (02-14-2020)
Old 04-29-2015, 03:13 PM   #5
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Two different part numbers, each can be used for drain and/or fill.
And yes, they are crush washers. You can reuse them being very careful and in you are in an emergency, but for the price, they should always be replaced.
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
CSG Mike (04-29-2015), givemeporknow (04-29-2015)
Old 04-29-2015, 04:41 PM   #6
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I love reusing crush washers just to live dangerously.
The Following 3 Users Say Thank You to King Tut For This Useful Post:
arkanist (02-14-2020), Icecreamtruk (02-14-2020), protpibe (05-01-2015)
Old 04-29-2015, 06:57 PM   #7
DuMa
DuMa's Avatar
Drives: LR BRZ Limited
anyone have the subaru part numbers for those diff washers?
DuMa is offline   Reply With Quote
Old 04-29-2015, 07:13 PM   #8
givemeporknow
Differential fill plug gasket: SU00300122 - 24mm OD x 18mm ID x 2mm Crush
Differential drain plug gasket: 1215710010 - 24mm OD x 18mm IDx 2mm Crush
I ordered two of the 1215710010 on ebay for about $2 each plus shipping and am gonna use it for both the fill and drain.
Old 02-14-2020, 07:33 AM   #9
DreamSpeedBRZ
Drives: 2017 86
Are the trans plug washers interchangeable with the diff's?
DreamSpeedBRZ is offline   Reply With Quote
Old 02-14-2020, 09:35 AM   #10
skylinekin
skylinekin's Avatar
Drives: 22 GR86, 13 FRS, 15 BRZ, 13 FRS
No those are aluminum washers and not the same size.
skylinekin is offline   Reply With Quote
The Following User Says Thank You to skylinekin For This Useful Post:
DreamSpeedBRZ (02-15-2020)
Old 02-14-2020, 02:22 PM   #11
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
I was looking at the fluid change package, curious as to why you need motul 300 LS. I thought it would be okay to use Motul gear 300- 75w90 for both transmission and diff?
DandoX is offline   Reply With Quote
Old 02-14-2020, 04:31 PM   #12
It is. The LS is actually a bit thicker even though the weight is still in the 75W90 category. For those that have aftermarket clutch type diffs, the LS also has the proper additive package.
Both will work in the stock torsen!
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
DandoX (02-14-2020), Icecreamtruk (02-14-2020), tomm.brz (02-14-2020)
Old 02-15-2020, 11:13 PM   #13
DreamSpeedBRZ
Drives: 2017 86
So the washers are interchangeable for the diff drain + fill
And for the trans drain + fill?
So I only need 2 different types of washers?
Are the trans the same as the oil plug's?
And lastly, I know the diff drain plug is magnetic, is the stock trans drain also magnetic?
I'm getting ready to change my fluids so I appreciate the info!
Old 02-16-2020, 12:16 AM   #14
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
No. They all use different washers
Transmission drain and fill are the same. They are solid type washers. The drain plug isn't magnetic as far as I remember.
Diff drain and fill are different from each other. Both are crush type washers. That isn't to say you couldn't just buy one and use it for both, but the parts catalog calls for different parts.
Obviously only one oil washer. Crush type
Subaru
1215710010 Diff Drain Gasket
11126JB000 Diff Fill Gasket
17008AA050 Transmission Gaskets
803916010 Oil Drain Gasket
Toyota
1215710010 Diff Drain Gasket (Toyota uses same PN as Subaru)
SU00300122 Diff Fill Gasket
SU00303626 Transmission Gaskets
SU00302159 Oil Drain Gasket
EndlessAzure is offline   Reply With Quote
The Following 2 Users Say Thank You to EndlessAzure For This Useful Post:
ddevl_86 (03-07-2021), DreamSpeedBRZ (02-16-2020)
Crush Washer Sizes Eric1855 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 55 08-30-2021 02:21 AM
Review soon:OS Giken Super Lock Limited Slip Differential + Greddy differential cover mav1178 Engine, Exhaust, Transmission 5 02-11-2021 01:20 PM
Crush Washer for AT BRZ888 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 07-27-2014 10:06 PM
Can the transmission crush washers be reused? brillo Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 11 04-15-2013 07:35 PM
Man Crush A Friend's Car With A 100-ft Axe ichitaka05 Off-Topic Lounge [WARNING: NO POLITICS] 11 01-19-2012 03:31 PM
