Old 07-11-2016, 02:11 PM   #1
BDKane01
BDKane01's Avatar
Drives: 2016 Subaru BRZ Limited CWP MT
Transmission&Diff crush washers reusable?
1st service will be this week and I will be doing the changes. Trans and diff included. I called to order the nesceary stuff listed in the technical article. The parts guy stated that the trans/diff gaskets/hardware are re usable as they are aluminum.
Not sure if true. Is it necessary to do this or is that true info?
Hindsight is 20/20
BDKane01 is offline   Reply With Quote
Old 07-11-2016, 02:18 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Some people flip them over and use them again, personally I would get new ones as they are dirt cheap usually.
BDKane01 (07-11-2016)
Old 07-11-2016, 02:19 PM   #3
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
I've always replaced them because they're pretty cheap and the dealership is literally next door to the storage unit where I do most of my work.
They ARE aluminum, and honestly you could probably just re-use them without issue since they are soft enough to probably re-seal just fine.
Stang70Fastback is offline   Reply With Quote
The Following User Says Thank You to Stang70Fastback For This Useful Post:
Old 07-11-2016, 03:33 PM   #4
gramicci101
Off Topic
The transmission drain and fill plug have gaskets, not crush washers. Which is why they're $11 each. They are reusable, although I'd replace them after two or three uses for peace of mind. The diff has crush washers and they will need to be replaced.
The Following 4 Users Say Thank You to gramicci101 For This Useful Post:
BDKane01 (07-11-2016), Bristecom (07-16-2016), Jasper (04-28-2021), roddy (07-13-2016)
Help! Washers for Oil/Trans/Diff Bevans555 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 05-12-2023 09:41 AM
Are the differential crush washers the same? givemeporknow Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 02-16-2020 12:16 AM
diff crush washers + AT gasket + satin white pearl touch-up paint autobrz Mechanical Maintenance and Tools 9 07-13-2016 04:40 PM
FS: 11x Subaru Oil Filters w/ Crush Washers (15208AA130) Argento_FR-S Mechanical Maintenance and Tools 2 04-01-2016 10:08 AM
Can the transmission crush washers be reused? brillo Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 11 04-15-2013 07:35 PM
