Old 08-25-2012, 06:12 PM   #1
BRZY
BRZY's Avatar
Drives: World Rally Blue BRZ
Part Numbers for Tranny & Diff Washer
Looking to drain my transmission and differential fluids out and fill them up with Amsoil. I tried calling Oakland Subaru/Toyota (same dealer) for these parts. The tranny & diff washers are special order since they do not stock them (yet?). As I understand from vast experience with Honda parts, special order parts are nonrefundable. Searching the forum, I found these part numbers:
Originally Posted by Opie View Post
Oil Drain Gasket: 803916010
M/T Fill plug gasket: 17008AA050 - I can't find the drain plug gasket in the parts lookup diagram BUT, it says it uses a quantity of 2 for the fill plug gasket....maybe they are the same?
Rear Diff Fill plug gasket: 11126JB000
Rear Diff Drain plug gasket: 1215710010
Can anyone confirm these are the correct washers?
Just in case anyone is wondering about the oil filter:
Oil filter: 15208-AA-130 (old style, better?)
http://www.ft86club.com/forums/showthread.php?t=12392
BRZY is offline   Reply With Quote
The Following User Says Thank You to BRZY For This Useful Post:
Sportsguy83 (11-28-2012)
Old 08-25-2012, 06:18 PM   #2
BRZY
BRZY's Avatar
if anyone have links to online sellers, please share.
Old 08-25-2012, 09:56 PM   #3
BMWDavid
Drives: '89 911, '06 GTI, '13 BRZ
+1
2005 Honda XR650L
1989 Porsche Carrera 3.2 Coupe
2006 VW GTI/DSG
2013 Subaru BRZ WRB Limited 6MT-gone but not forgotten
2014 Nissan Murano SV
BMWDavid is offline   Reply With Quote
Old 09-21-2012, 06:31 PM   #4
ft86Fan
ft86Fan's Avatar
Drives: FR-S, Exige S, Miata
I just went to both Subaru and Toyota dealer for these washers/gaskets. The Subbie dealer doesn't have any in stock and has to order them because he said the tranny is made by Toyota (Isn't it an Aisin AZ6?). He told me the tranny washers are over $8 each so I said no thanks and went to the Toyota dealer. Toyota tells me its over $11 each . Anyway, these are the parts number I got from them:
Differential fill plug gasket: SU00300122 @$2.30 each
Differential drain plug gasket: TOY1215710010 @$1.50 each
Transmission fill/drain plug gasket: SU00303626 @>$11 each
I'm assuming the new "SU" parts number means they are Subaru parts? I only got the drain plug gasket for the differential since that is the only one they have now. I believe its because it has the old parts number and they used it for other vehicles also. I'm not going to sweat the fill plug gasket for the diff. I'm just going to flip the old one and reuse it. The fill plug is near the top and the differential is not under any pressure so I'm sure it'll be fine.
'13 Scion FR-S (Whiteout)
'07 Lotus Exige S (Aspen White) Touring, Traction, Starshield
'95 Miata (Montego Blue)
ft86Fan is offline   Reply With Quote
The Following 2 Users Say Thank You to ft86Fan For This Useful Post:
Bristecom (09-23-2012), MattR (09-25-2012)
Old 09-25-2012, 03:51 PM   #5
xn7485
Drives: 1995 Acura Integra GS-R
Just got a both pairs with part numbers quoted from Opie at Subaru. Rear diff drain and fill plugs look identical, but are both crush type washers. I recommend getting new ones to form a better seal. Price is 1.73 for fill, 1.98 for drain.
Yes, the transmission fill/drain washers are freaking $7.87 each. These are solid washers, and do not seem like they require replacing, but I special ordered these so I bought them. Though I got them at net price it was still freaking $5.19/washer.
xn7485 is offline   Reply With Quote
The Following User Says Thank You to xn7485 For This Useful Post:
ft86Fan (09-25-2012)
Old 03-26-2015, 02:20 PM   #6
kanundrum
Drives: 2013 Whiteout FR-S
Could there be another part # for SU00300122 ? I can't seem to find it in certain parts catalogs.
The Following 2 Users Say Thank You to kanundrum For This Useful Post:
Tart (09-17-2016), T_riggidy (04-03-2015)
Old 08-27-2015, 04:06 PM   #7
rixter145
Sleep Chomper
rixter145's Avatar
Copper gaskets from O'Reilly's can be substituted for transmission gaskets they say. OIL-TITE! PN# 65275 11/16", M18
rixter145 is offline   Reply With Quote
Old 08-27-2015, 04:58 PM   #8
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Anneal, flip, and reinstall.
Decay107 is offline   Reply With Quote
The Following User Says Thank You to Decay107 For This Useful Post:
Grady (05-12-2023)
Old 08-28-2015, 10:12 PM   #9
PWBRZ
PWBRZ's Avatar
Drives: 2013 BRZ 6MT
I just changed my trans and diff fluids today. I got the necessary washers at:
www.belmetric.com
PWBRZ is offline   Reply With Quote
The Following User Says Thank You to PWBRZ For This Useful Post:
steezypenguin (08-28-2015)
Old 09-10-2015, 09:41 PM   #10
Donbrz
Drives: 2015 Brz Blue Series
www.belmetric.com
Part # references on belmetric website?
Donbrz is offline   Reply With Quote
Old 09-11-2015, 01:32 AM   #11
PWBRZ
PWBRZ's Avatar
Transmission
2 flat washers - 24mm OD x 18mm ID x 2mm (drain and fill are same size)
Belmetric: GA18X24T
Differential
2 crush washers - 24mm OD x 18mm ID x 2mm (drain and fill are same size)
Belmetric: GCA18X24
The stock washers I took off the transmission were virtually identical to the Belmetric GA18X24T.
The stock washers from the differential were similar to Belmetric GCA18X24 but not copper. To be honest, if you wanted to you could even use the same ones used for the transmission. Just make sure to use a torque wrench to get proper torque to 'crush' the washers.
The Following 6 Users Say Thank You to PWBRZ For This Useful Post:
Donbrz (09-11-2015), jflogerzi (02-11-2021), Lakitu (06-19-2018), nomtimesthree (03-23-2024), robotleader (03-15-2022), Wally86 (03-24-2025)
Old 09-11-2015, 11:00 AM   #12
Donbrz
Transmission
Belmetric: GA18X24T
Differential
Belmetric: GCA18X24
Thanks. Just ordered. Much lower prices than subaru dealer
Old 05-12-2023, 07:19 AM   #13
r4mr4m3024
Drives: gt86
Thanks for the info, have you had any leaks yet? And it works like the original version?
r4mr4m3024 is offline   Reply With Quote
Old 03-20-2025, 01:20 PM   #14
Kamber
Drives: '22 BRZ | '21 Supra
Unfortunately, the Belmetric offerings seem to no longer be available 7 years later.
If anyone finds this thread looking for 3rd part alternatives to the stupid expensive-for-what-they-are OEM gaskets, check these out if you're looking to buy everything in one go, or the below if looking to order separately.
OEM Trans drain/fill gaskets are 18x24x2mm flat washers
- Copper 18x24x2mm washers
- Another copper 18x24x2mm washer option from a different Amazon vendor
- PTFE 18x24x2mm washers
- Copper 18x24x1.5mm washers
- Aluminum 18x24x1.5mm washers
OEM rear diff drain/fill gaskets are 18x24x2mm crush washers
- Searching "1215710010" on Amazon will yield tons of results for that are great bang for buck (15-30 pieces for anywhere from $5-10 with prime shipping)
Kamber is offline   Reply With Quote
The Following 3 Users Say Thank You to Kamber For This Useful Post:
JeffForSale! (02-01-2026), kevaughan (06-24-2025), Wally86 (03-24-2025)
Badge / Wheel cap Part numbers lordtakuban Cosmetic Modification (Interior/Exterior/Lighting) 10 09-09-2012 04:43 PM
Part numbers 20valvewynn83 Cosmetic Modification (Interior/Exterior/Lighting) 1 07-24-2012 06:16 AM
How do I get JDM part numbers? InstantNoodles Cosmetic Modification (Interior/Exterior/Lighting) 2 07-09-2012 04:29 PM
Subaru part numbers for stock brake rotors? blalor Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 06-28-2012 02:31 PM
part numbers Staticfrost BRZ First-Gen (2012+) — General Topics 5 05-29-2012 12:02 PM
