Old 04-02-2017, 11:58 AM   #1
randomthoughts
Drives: 2014 White BRZ
Windband sensor location with OFT stage 2
Can I remove one of the o2 sensors to be used for a gauge or does OFT stage 2 uel tune require both sensors?
randomthoughts is offline   Reply With Quote
Old 04-02-2017, 04:11 PM   #2
steve99
you would have to make a few changes to tune to be able to remove the rear 02 sensor.
Alternatively you could just rescale the front 02 sensor as its capable of reading quite well down to 10 afr.
http://www.ft86club.com/forums/showthread.php?t=82875
use the values in this post
http://www.ft86club.com/forums/showp...8&postcount=16
Old 04-02-2017, 04:36 PM   #3
randomthoughts
Ok thanks. I think I'll get a bung welded in and run a separate sensor for my gauge
Vehicle Speed Sensor Location or Pin Out jjkerr626 Engine, Exhaust, Transmission 6 06-21-2018 11:09 AM
A/F Wideband O2 Sensor Bung Location FyeaFRS Engine, Exhaust, Transmission 2 06-01-2015 09:17 AM
O2 Oxygen Sensor Fuse Location? Synack Engine, Exhaust, Transmission 6 04-09-2015 09:47 PM
Eng coolant temp sensor location D K Engine, Exhaust, Transmission 28 08-27-2014 05:30 PM
OEM Oil Temp Sensor Location Khorne Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 01-15-2014 10:38 PM
