Old 04-03-2015, 03:29 PM   #1
jjkerr626
jjkerr626's Avatar
Drives: 2013 Subaru BRZ Sport Tech
Vehicle Speed Sensor Location or Pin Out
Hello everyone, can someone tell me where the VSS wire is located on the car?
I am trying to tap into vehicle speed signal for the TEIN EDFC.
Any help would be appreciated, thanks.
Performance Parts: Innovate Motorsports Supercharger, Mishimoto Oil Cooler, Borla UEL Header, Perrin Cold Air Intake, Perrin Cat Back Exhaust, Perrin Crank Pulley, Perrin Rear Shifter Bushing, Perrin Transmission Bushing, Perrin Master Cylinder Brace, Billet Pro Short Shifter. Handling Parts: Perrin Control Arm Braces, Perrin PSRS Offset Steering System, Perrin 22mm Front & 22mm Rear Sway Bars, Perrin Spherical Rear Endlinks
jjkerr626 is offline   Reply With Quote
Old 06-02-2016, 07:11 PM   #2
Initial_RD
Drives: Subaru BRZ
@jjkerr626 were you able to find the VSS location to tap for EDFC? I'm curious as well (sorry to revive old thread but I've searched online and no luck)
Initial_RD is offline   Reply With Quote
Old 06-02-2016, 07:36 PM   #3
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
http://www.ft86club.com/files/BRZwiringi.pdf
Feel free to search for the words "speed sensor"
-alex
Old 06-02-2016, 10:45 PM   #4
Initial_RD
Drives: Subaru BRZ
-alex
This helps a lot! Much appreciated!
Old 06-20-2018, 01:03 PM   #5
ldam
Drives:
sorry to bring up an old topic, i'm trying to do the same thing with my edfc active pro, i was just wondering which wire did you end up connect to in your vehicle
ldam is offline   Reply With Quote
Old 06-21-2018, 09:23 AM   #6
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
wheel speeds are canbus through the abs module
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
Old 06-21-2018, 11:09 AM   #7
ldam
Drives:
I finally found the answer from an old topic post by kothetimeless the diagram below should help
Vss cable is #17
Work with EDFC active pro
DOT Proposes Mandating Cars Broadcast Location, Direction and Speed Tromatic Other Vehicles & General Automotive Discussions 27 08-28-2014 08:27 PM
Eng coolant temp sensor location D K Engine, Exhaust, Transmission 28 08-27-2014 05:30 PM
Boost Up Your Vehicle's Speed, Power, & Track Times at FR Sport! FRSport.com Forced Induction 0 01-24-2014 12:33 PM
OEM Oil Temp Sensor Location Khorne Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 01-15-2014 10:38 PM
Engine Speed vs Vehicle Speed for 6MT DetroitJake Engine, Exhaust, Transmission 22 04-27-2013 06:56 PM
