Old 08-20-2016, 01:13 PM   #1
Veloist
Veloist's Avatar
Drives: ‘93 MR2, ‘22 GR86, ‘23 GR Corolla
2017 BRZ Performance Package Brembo Brakes Part Numbers
Diagrams and Part Numbers are now available.
Front Brake Brembo: http://parts.subaru.com/a/Subaru_201...10-262-03.html
Rear Brake 17inch:
http://parts.subaru.com/a/Subaru_201...10-263-03.html
I'm not too much of technician so would anyone be able to chime in on how one would be able to swap the stock brakes to this setup (I'm sure a couple of people are curious)?
Veloist is offline   Reply With Quote
Old 08-20-2016, 01:24 PM   #2
makesdrivingfunagain
That could be a real benefit to some for sure. I would like to know if there is any weight loss with this swap as well.
2013 FR-S, AT, Braille 15lb battery, 16x7 Wedsport SA15R w 205/55/16 Continental Extreme Contact Sport, TRD drop in airfilter, TRD spring and TRD swaybars, TRD exhaust, TRD Brake Pads,4:56gear, 2740lbs
makesdrivingfunagain is offline   Reply With Quote
Old 08-20-2016, 03:09 PM   #3
ryoma
ryoma's Avatar
I would assume you will need the full brake caliper, caliper bracket, and rotor to do a swap. I am not sure if the front rotor is a different size than previous MYs though. same goes for the rear. I haven't really paid much attention to the specifics.
Old 08-20-2016, 04:29 PM   #4
prj3ctm4yh3m
Drives: CRV AWD 5MT
those pad prices wow.
prj3ctm4yh3m is offline   Reply With Quote
Old 08-20-2016, 04:41 PM   #5
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Smart money is on a BBK, not this.
Old 08-20-2016, 05:00 PM   #6
gramicci101
Off Topic
The rotor sizes are the same as the STI. 326x30 front, 316x20 rear. It's not just an STI parts swap though. The pistons are different sizes than the STI calipers; presumably sized for correct bias for our cars.
Old 08-20-2016, 11:59 PM   #7
This.
Old 08-22-2016, 10:46 AM   #8
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Am I reading the price right? $300 a caliper?? I assume they have just not updated the pricing yet... The Part number is also the same between the Brembos and the normal calipers.
Almost wondering they are going to require a vin to order them from the dealer.
DustinS is offline   Reply With Quote
Old 08-22-2016, 11:08 AM   #9
langjai23
Drives: 14 brz
the pricing for the caliper doesn't seem bad. I wouldn't use the stock pads so the pricing on that part is not a concern.
it looks like just a bolt on bracket to mount it like the current aftermarket solutions.
langjai23 is offline   Reply With Quote
Old 08-22-2016, 11:19 AM   #10
ajc209
Drives: GT86 Cosworth
How can you tell. I cant see any info about the pistons?
ajc209 is offline   Reply With Quote
Old 08-22-2016, 11:36 AM   #11
gramicci101
Off Topic
Here you go.
Originally Posted by Stang70Fastback View Post
Old 08-22-2016, 12:00 PM   #12
ajc209
Here you go.
Thanks interesting. Surprised there is no piston stagger to help pad tapering.
They have made the front pistons smaller on both the normal disc and Bremo disc. The pistons are 42.8mm on our 2 pot sliders but now ~40mm.
Rears are currently 38mm on the 290mm disc. So going up to 40mm at the back adds more rear braking.
Punching the numbers into my spreadsheet.
The current 2012-2016 model has a brake bias of about 64% to the front.
The new model is now 61% to the front.
The brembo package is 60% to the front.
This compares to the STI Brembo front and rear of 74% to the front.
Old 08-22-2016, 02:25 PM   #13
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Caliper isn't even listed . Looks like we are better off getting a BBK as someone stated above or ATS swap.
Old 08-22-2016, 02:29 PM   #14
DustinS
DustinS's Avatar
Originally Posted by NyC Zn6 View Post
Caliper isn't listed. Looks like we are better off getting a BBK as someone stated above.
Technically "26292A DISK BRAKE KIT-PAD LESS,FRONT LEFT" Is the left brembo caliper. Though the part number/price has not been updated from the non-brembo calipers. So although they are listed, they are not correctly listed?
CSG Brembo Brakes LenA Suspension | Chassis | Brakes -- Sponsored by 949 Racing 29 07-12-2024 10:05 AM
Real STI BREMBO package upgrade - DIY Trap63 DIY (Do-It-Yourself) Guides 40 06-15-2022 09:25 PM
EVO 7 BREMBO FRONT BRAKES ON BRZ? NOTORIOUS.BRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 01-26-2016 12:24 AM
Evo X brembo brakes Justkiz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 08-12-2013 02:00 AM
R35 Brembo Brakes - Full set 2013GTRNate Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 10-06-2012 10:08 AM
