Drives: 2015 Silver BRZ
CSG Brembo Brakes
I saw a 326mm front Brembo kit on CSG site. Do these brakes require spacer for stock wheels and are they lighter than stock brakes. They look like they use 1 piece rotors and 4 piston calipers
Thanks Len |
Drives: 2014 GT86
Most sites also list contact page. It's worth using emails listed there to get info about some specific products. Brembo-s (unless some STI retrofits which i don't advise doing) are not the most common (probably due price) on toyobaru. Forum crowd might have less info on uncommon products then shop selling it.
| The Following 2 Users Say Thank You to churchx For This Useful Post: | Captain Snooze (04-02-2022), NoHaveMSG (05-02-2018) |
Yeah, probably a better idea. I'll post what I find out in case anyone else is interested
Len |
Drives: 2014 GT86
Oh, ignore my comment. It seems that i was in impression you were asking of previous brembo kits offered by CSG, that costed $7.5-8.5K. I see they have added both front and rear brembo kits "Brembo GT System CSG-Spec" costing 1/4th of price of those and marked as *NEW*. At that price level they might get wider user base.
They list kit product numbers though, so you can try searching on those on eg. brembo site, to see if they have some BBK fitment templates to print out and check on your wheels. |
Drives: Asphalt Scion FR-S
I contacted CSG and spoke with Mike over the phone about the kit and it will require a 20mm spacer to fit stock wheels. They are lighter than stock brakes, but not AP Racing light. They include 1 piece rotors so cost of entry is lower and over time can be upgraded to 2 piece rotors to further reduce weight. The Brembo GT caliper allows for thicker pads. That's all the basic info. Would definitely recommend giving them a call to find out further details.
| The Following User Says Thank You to JDKane527 For This Useful Post: | Tanstin (02-06-2021) |
Well, what would you like to know? The kit overall is lighter; the rotors are heavier (they are, after all, much larger than stock). You will need a 20mm spacer to clear stock wheels. Maybe (speculated) 15mm for the 17 performance pack wheels.
| The Following User Says Thank You to CSG Mike For This Useful Post: | wparsons (05-02-2018) |
Thanks for reply. I don't really need better brakes yet, but trying to identify options when I get to that point where I do need/want to upgrade.
Len |
#10 |
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
#12 |
Drives: ft86
are the rotors off the shelf?
#14 |
Drives: 86
For anyone reading, these are the brakes the OP is asking about:
CSG Spec Brembo Big Brake Kit for Subaru BRZ / Toyota 86 / Scion FR-S Great kit, but there's no one size fits all when it comes to brakes. CSG can steer you to the right solution based on your needs and budget
| EVO 7 BREMBO FRONT BRAKES ON BRZ? | NOTORIOUS.BRZ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 01-26-2016 12:24 AM |
| Fake Brembo's AP Racing Calipers/Brakes | STIITS | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 60 | 08-20-2014 11:11 PM |
| Evo X brembo brakes | Justkiz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 08-12-2013 02:00 AM |
| Brembo GT Brakes fitments BRZ/FT86 | Trap63 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 05-05-2013 09:39 AM |
| R35 Brembo Brakes - Full set | 2013GTRNate | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 10-06-2012 10:08 AM |
