R35 Brembo Brakes - Full set
If you had a full set of R35 brakes 6Pot front and 4Pot rear would you do the mods required to install on your FR-S/BRZ?
-Nate |
Because compromise ®
Drives: Red Herring
No
Drives: FJ Cruiser
Depends on what needed to be done... but probably.
Drives: Raven Black
Mods like a turbo kit with 25 lbs of boost and 500WHP, big enough rims to fit, fat enough wheels to handle the power, quality coil overs to handle the bumps and provide proper stance, hubs to match up the to the rotors calipers?
$12,000+ in mods just to fit some R35 brakes overkill unless you put alot more power and $$$$$ into the car |
#5 | |
Drives: 2012 BRZ Premium WRB 6MT
Long answer: If I wanted to spend a lot of money and time, and only have something that looked cooler than stock, but didn't work as well and screwed up my car's dynamics, I'd consider it. To get R35 brakes on a FT86, you'd need to do the following design and fabrication work:
Only reason to do it: It would look cool on a show car sitting still under shiny spotlights. Main reasons not to do it:
Even if you got the GT-R brakes for free, you'd still spend more money trying to get them on the car and operating properly than you would just buying an aftermarket brake system designed specifically for the FT86. This is one of the most classic mistakes in all of the aftermarket, and I've seen it many times. It always starts with a phone call, "I got a great deal on a set of XYZ brakes..." It usually ends with another call a few months later saying, "I give up, please sell me some brakes designed for this car, and put me out of my misery." My advice would be to buy a GT-R if you really want GT-R brakes, or buy a brake system designed specifically for the FT86 platform if you want better looks and performance. Brembo is selling a nice six piston front / four piston rear setup, I believe StopTech may be as well, and my company will be offering an AP Racing brake system with a 6 piston front/4 piston rear. I know Baer was working on a brake system for these cars, and I'm sure there will be others. There are lots of options out there that will cause you considerably less anguish than trying to fit a square peg into a round hole. That's my insight after dealing with many thousands of aftermarket brake customers over the past 10 years. Do with it what you will. :happy0180:
Essex Parts Services- AP Racing / Ferodo / Spiegler / Versodeck
Jeff Ritter|Mgr.- High Performance Division www.essexparts.com ![]() |
TY guys… I will hold on to them and leave the car as is...
#7 | |
Drives: BRZ L 6MT, 128i 6MT, E39 M5, E36 M3
Bravo.
I will say that in the past on my 300ZX TT I installed a larger set of GTR R34 Brembo's with outstanding results. I had to drill out the hubs because the caliper bolts for the GTR brakes were larger than the 300ZX original caliper bolts. I also purchased a secondary set of hubs in the event that any mistakes were made, I also went to a local shop that made brake lines and had some custom fabbed steel braided brake lines. I agree with your post for the most part but there are always exceptions to any rule… Sometimes you can invest in aftermarket brakes made specifically for your car and get a bad product. I have seen this many times over with multiple platforms… I will not bash the actual products or their vendors in this post since I have no scientific proof, but it does happen.
My BRZ is destined for DD duties and will not become a track toy until after warranty expiration and most likely 100K of miles… Most of the time a better set of brake pads/ slotted rotors and some racing brake fluid will give a lot more of performance boost that anyone would suspect… I may still attempt this or a similar project but that will be years down the road when the value of this car is much less and it is easier to justify… :happy0180: -Nate |
Señor Member
Drives: white BRZ 6MT
I would sell them an just by a brake kit that fits properly
| GRB Brembo caliper on BRZ | RavSpec | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 66 | 11-15-2016 02:50 PM |
| Brembo BBKs Announced | oneday | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 82 | 06-11-2014 10:51 PM |
| KW Coilovers, Brembo Brakes, Cusco and more! at Vivid Racing | vividracing | Brakes, Suspension, Chassis | 5 | 10-15-2012 06:23 PM |
| GT brakes | jello | AUSTRALIA | 2 | 06-10-2012 09:10 AM |
