Drives: Fast
Track wheel and tire size?
What wheel and tire size seems to work best for the track?
I plan on running NT01's, just not sure how big to go with the horsepower that is available. |
Drives: 2005 Toyota Camry
.... what's the available horsepower?
Drives: Fast
Stock.
depending on your driving style, 225 up to 245 would be perfectly fine for track use.
245 will result in slightly slower times if there's a lot of higher speed straights on the course. Wheel widths will be preference but should match the tires. 17x7.5" w/ 225/45-17s will be a killer combo, esp if there is big brake clearance. 17x8" w/ 235 or 17x9" w/ 235 or 245 tires would also work. -alex |
| The Following 3 Users Say Thank You to mav1178 For This Useful Post: |
Drives: Track preped NA FRS
If the nittos NT01 are sized like the Maxxis RC1 (both comparable R compounds) they will actually be bigger than street tire size. What I mean is, my 225 RC1 are actually as wide as my 245 PSS. If you get 245, make sure you realise that it wont probably fit on stock suspension (either touching the spring, or the fender depending on your wheel offset). 225 might be my sugestions. Im full exhaust + tune and running 225 RC1 I cannot power oversteer the car at all unless im really trying to drive bad.
| The Following User Says Thank You to Icecreamtruk For This Useful Post: | cab33 (05-13-2016) |
Drives: Fast
I'm running 245/40/17 Rival-s tires on 7" wide wheels for Autocross CS right now without issue. I have the TRD lowering springs and TRD sway bars also.
I have this urge to get 245's on wider wheels for the track but I just don't want it to be too much for the horsepower. |
[insert cool phrase here]
Drives: BRZ Premium
Pretty much what mav1178 said.
Then again I seen Miatas spank everyone on 205/50/15. So...... Tires < driving skill.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
Drives: 13' Scion FRS Track car
I recommend 225. and if you start sliding around, think about your corner entry.
larger tire will mask many mistakes but you will be slower. Go fast on 225 to refine your skills, if you are just in for a few laughs in the turns, at high G's then go for the 245, it is fun to play with the grip.
2013 Scion Frs Track Car - Sold.
| The Following User Says Thank You to philooo For This Useful Post: | kch (05-18-2016) |
#10 |
Drives: 2013 BRZ Limited
And Compound >>>>>> Size
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523 Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car www.makesmodels.com www.camautomag.com |
| The Following User Says Thank You to zdr93523 For This Useful Post: | STV3 (05-18-2016) |
#11 |
Drives: '23 BRZ Limited
Not to mention weight, HP, suspension setup, etc. That's not even a remotely valid comparison.
#12 |
Drives: 2013 scion frs
I run a 17 x 7.5 with a 225 rival/ rs3 v2. Never had an issue with grip.
Im also in the boat of compound > width.
Speed has never killed anyone, suddenly becoming stationary… that’s what gets you. – Jeremy Clarkson
#13 |
Drives: 2013 WRB BRZ 6MT
NT01 is a great compound, I'd personally start with a 225/45ZR17 with the largest rim width they recommend for the tire which is an 8.5 but an 8.0 would be fine too. Nice thing about these rim sizes is that you can safely go to a 245/40ZR17 later if you like. The NT01 has a very stiff sidewall so running it stretched or pinched shouldn't impact response too much.
| Wheel/Tire size help!!! | jordanlee2393 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 06-07-2015 07:11 PM |
| Tire/wheel size help needed | gdrider77 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 12-28-2014 08:39 PM |
| wheel and tire size questions | BRZ21 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 11 | 11-02-2014 04:46 AM |
| Help with wheel\tire size for a DD on Pro Kit | B-R-Z | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 04-08-2014 02:06 PM |
| Need advice on tire size for track duty?? | track_warrior | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 02-05-2013 08:50 PM |
