Old 06-07-2015, 08:29 AM   #1
jordanlee2393
Drives: 2015 Subaru BRZ Limited
Exclamation Wheel/Tire size help!!!
Okay so i love how the car handles stock, hugs like crazy and im sure you guys just know what im talking about. Here is my problem just tried going with 17x8 niche targa m130 (love the wheels okay) and i tried running the 245/40R17 continental extreme contact dw but the car was completely different when it came to handling! It was not nearly as tight around the corners and so i couldnt push it as hard. So do i just need maybe a staggered setup? Like go 225/45R17 in the front (personally i think the rears are fine performance wise for grip and aesthetically) to help with the handling or would some suspension upgrades do the trick? Open to any suggestions, oh and by the way if there is an awesome 18" setup anyone has had great success with im up for that because we have to send the wheels back anyway because they are defected! So please any and all suggestions welcome!
jordanlee2393 is offline   Reply With Quote
Old 06-07-2015, 08:45 AM   #2
Bergen23
Drives: '15 Halo FR-S
You put too much tire on, which will make the car feel slow.
Bergen23 is offline   Reply With Quote
Old 06-07-2015, 10:33 AM   #3
churchx
churchx's Avatar
Drives: 2014 GT86
Too grippy & wide tires for stock power level and staggered tire setup both are wrong if you want to keep character and balance stock had. Best (and also cheapest) bet would be keep using stock sized tires. Tinkering with suspension changes/upgrades .. why fix thing you made worse trying other ways/upgrades instead of reverting that mistake in first place? Imho this thread is worth reading.
I wouldn't also think that upsizing wheels is right if you care more about handling then looks. Stiffer sidewall tires at right pressure will help more sharper turn ins then one inch bigger wheels. Unless you must have (doubtful for daily driving) big brake kit (many of which fit fine in 17") that is not cleared by 17", there is no reason except looks to change rims to bigger ones, that will be heavier, slightly robbing acceleration, adding weight (i know that there are few lighter 18" then stock. But 17" of same type will be even lighter anyway), making suspension work harder. Pay to make worse thing you care for?
Old 06-07-2015, 10:39 AM   #4
Sammakko
Bilge monkey
Sammakko's Avatar
Drives: '13 BRZ, 82 starlet
heavy wheels...
try some rpf1's and BFG rivals... transformation.
Sammakko is offline   Reply With Quote
Old 06-07-2015, 12:40 PM   #5
WNDSRFR
Drives: FR-S,GTI
I went through a set of Extreme Contacts in a 235/45/17 size (well not a "set". I still have them on the front). I hated them. They had the softest sidewall I have ever seen and the rears were bald in less than 5K miles. I switched to Champiro UHP's on the rear. I getting ready to get rid of the Conti's and replace them with the Champiro's all round. They handle much better and are quite a bit cheaper.
Old 06-07-2015, 06:11 PM   #6
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
If you want to bump up the precision and agility from stock, upgrade to 205/45-17 Max performance tires all around on 17x7.5 wheels... tread width of the 205/45-17 Kumho Ecsta Sport LE set I just wore down to slicks is wider than the stock 215/45-17 tires by .2" and they are much more planted at high speed, not to mention WAY better in the wet (the stock tires are not very good in wet performance) all the way down to the wear bars! I'm back on the original stock tires now (to save some money) and while they are nice in the dry, I'm missing the Sport LE's already, even if though they only lasted ~10k miles until being completely worn down to slicks (they were less than $300 for the set!)
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
brz, inch, performance, tires, wheels
Tire/wheel size help needed gdrider77 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 12-28-2014 07:39 PM
wheel and tire size questions BRZ21 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 11-02-2014 03:46 AM
Help with wheel\tire size for a DD on Pro Kit B-R-Z Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 04-08-2014 01:06 PM
Wheel + tire: size vs weight vs confusion horrorbiz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 07-14-2013 12:48 PM
Help me decide on tire/wheel size... wparsons Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 01-17-2013 03:45 PM
