Old 02-07-2016, 09:45 PM   #1
WGMGR
Drives: WRB Limit BRZ 2015
Grinding noise in neutral
What could this be? Sitting in my drive way in no gear itll make a grinding noise but when I push the clutch in itll go away, it also doesn't make the noise when I go as far as I can tell
WGMGR is offline   Reply With Quote
Old 02-07-2016, 09:49 PM   #2
stevesnj
stevesnj's Avatar
That's the throw out bearing, it's normal. If you get a screeching sound get it replaced. Until then turn up the tunes.
My 2016 Build thread
Old 02-07-2016, 11:56 PM   #3
google "neutral rollover."
Old 02-08-2016, 01:14 AM   #4
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
Is it a serious problem? Because i have that noise too.
Is it self fixable or do i need to take it back to toyota?
FR-Sky is offline   Reply With Quote
Old 02-08-2016, 01:24 AM   #5
If the transmission doesn't make any noise while driving then there's nothing wrong.
Idle up to about 2K RPM. I bet the noise goes away.
Old 02-08-2016, 01:31 AM   #6
FR-Sky
FR-Sky's Avatar
So far i only hear it when its idling/neutral. What is transmission sounds like?
I have a N1 exhaust...so i cant hear if the noise goes away or not....
I just try with my dad rev about 2000rpm,, the rattle noise still exist!
Old 02-08-2016, 01:43 AM   #7
Do you have a lightweight flywheel?
Old 02-08-2016, 01:54 AM   #8
FR-Sky
FR-Sky's Avatar
Everything stock beside drop in k&n air filter and invidia exhaust.
Old 02-08-2016, 02:02 AM   #9
Very few mechanical things that go bad ...... fix themselves, including a bad TOB.
I'd suggest you pay a visit to your dealer and ask to listen to another FR-S for a comparison. While you are there, you may consider asking a tech for an opinion.
Ultramaroon (02-08-2016)
Old 02-08-2016, 02:08 AM   #10
Most manual transmissions, when the clutch is NOT engaged, have a shaft(s) that rotate. This is a "transmission" sound, some call it a "rollover" sound.
It kinda sounds like a quiet clothes dryer, running on low speed, when it's empty.
Old 02-08-2016, 02:10 AM   #11
FR-Sky
FR-Sky's Avatar
I mean as long is normal,,then i am fine with it.
I just did a little bit research right now,,many people say its a high pressure fuel injection, and its normal. so i dont know...
Old 02-08-2016, 02:12 AM   #12
It's probably a good idea to have a dealer tech give it a listen. A little neutral rumble is no biggie but who can say when it becomes excessive?
Old 02-08-2016, 02:15 AM   #13
We're specifically discussing the sound of the transmission in neutral. this sound will disappear when you push in the clutch. If it doesn't disappear then it's not the transmission.
humfrz (02-08-2016)
Old 02-08-2016, 02:24 AM   #14
FR-Sky
FR-Sky's Avatar
sorry...i dont have this problem...
But i do have the rattling noise problem when idling/neutral.
Transmission Noise in Neutral @ Cold Start Jackal84 Issues | Warranty | Recalls / TSB 57 03-01-2021 04:21 PM
clutch grinding noise BoxerBlock88 Engine, Exhaust, Transmission 13 11-14-2015 07:12 AM
Grinding noise during slalom JM197 Issues | Warranty | Recalls / TSB 9 08-11-2014 11:50 PM
Grinding noise? frs10 Issues | Warranty | Recalls / TSB 7 09-20-2013 11:57 AM
MT, neutral 15-10mph slowing, ratcheting noise bcj Engine, Exhaust, Transmission 7 04-18-2013 01:33 AM
