Old 07-24-2014, 12:45 PM   #71
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Originally Posted by gramicci101 View Post
Take spare coils for 1 and 3!
I havent heard anything from Wonderbar about cutting out a heat shield. I'm still trying to find a diagram showing physical measurements of the coils so I can bug the aftermarket ignition companies about suitable substitutions. I'm sure there's already something developed for another car that would work just fine, it's just a matter of finding it.
There is a pretty common upgrade for RX8's that keep blowing coils to use coils for the LS(x) V8 engines that are fairly inexpensive (vs. OEM). They are also much better and don't fail like OEM ones so maybe look into those and see if they might work on our twins.
Slick is offline   Reply With Quote
Old 07-24-2014, 12:56 PM   #72
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Two new revised part number OEM coils should be arriving tomorrow in the nick of time. I'm replacing my #3 which is throwing P0353 with a new one and keeping another as a spare. My #1 was replaced back in March with the same CEL issue (P0351) and has been fine since.
Don't want to go too off topic but there's ongoing discussion on this issue including the idea of using the popular GM coils with heat sinks on them here: http://www.ft86club.com/forums/showthread.php?t=30879
Though the LSX coils are an odd shape and have a very slim chance of fitting in the FA20 heads as-is.
Old 07-24-2014, 01:00 PM   #73
gramicci101
Off Topic
You think it would be worth using your brake duct hose from that side to route cool air over that area? Since you're using the GT3 ducts for your brakes now, the brake duct could be repurposed. It would at least keep the heat from the exhaust from stagnating right over the coils.
That may pressurize the engine bay though, without some way for the air to escape. @plucas or @eric6 might be able to speak towards that.
Old 07-24-2014, 01:17 PM   #74
ATL BRZ
ATL BRZ's Avatar
It may help to an extent it but I sold my TF brake cooling kit as a whole to @AZP Installs. I think the head is going to heat soak the coils either way and the overpipe without a ceramic coating or heat shield is just going to accelerate the heat soak on that side. At this point I feel that a high performance coil with a heatsink and hotter spark is the best solution and would kill two birds with one stone.
Old 07-24-2014, 02:11 PM   #75
knipple
Drives: 2013 Ultramarine Scion FR-S
The Endurance is actually easier to clear with most wheels than the sprint.
Do you know if Enkei RPF-1 17x9 et +35 will clear the Endurance kit?
knipple is offline   Reply With Quote
Old 07-24-2014, 03:20 PM   #76
No, but I'll find out
Old 07-24-2014, 03:31 PM   #77
chonody
Drives: 2013 Subaru BRZ
I recently installed some Porsche brake ducts and noticed that the brake dust shield pretty much blocks the flow of air. So I took some tin snips and went to town. I just cut off the very tip of the shield right under the bolt. Bent it out a little bit, filed the rough edges, and sprayed it black to prevent rust and ugly. Good to go!
chonody is offline   Reply With Quote
Old 08-03-2014, 10:50 AM   #78
fstlane
fstlane's Avatar
Drives: BRZ Limited
I chose a slightly different implementation of the Porsche ducts by using ones from a 993. I like the profile and they match the contour of the control arm rather well. I wanted something to add a little brake cooling capacity for an occasional track day but the car needs to remain legal for autocross STX class.
fstlane is offline   Reply With Quote
Old 08-03-2014, 03:01 PM   #79
ATL BRZ
ATL BRZ's Avatar
Looks good. How did you mount those to the arms? I see they have tabs for screws on the back of them but I'm not sure you were able to use those.
Old 08-03-2014, 03:58 PM   #80
fstlane
fstlane's Avatar
Drives: BRZ Limited
Thanks ATL BRZ! I just used 3M automobile attachment tape across the face of the control arm as well as under the taps that rests on top. I originally planned on drilling a couple of holes to run cable ties through as well but it's surprisingly secure as is. I suppose someone could drill a small hole for a screw or bolt without compromising the integrity of the arm.
Here's a picture of the back of the scoop while I was mocking up the tape placement. The tape I had wasn't wide enough so I ran two strips and cut pieces for under the tabs.
I went ahead and installed a couple of cable ties just for good measure.
Old 08-12-2014, 09:57 AM   #81
Slick
Slick's Avatar
Will be working on completing the brake ducting on my car this weekend but looking for feedback on another issue:
Broken Bolts.
In the past month I have broken a caliper bracket bolt, 4 dust shield bolts and I am now finding that some of my front wheel studs are getting harder to torque consistently.
Background:
  • Had car since June 2012
  • Winter driving
  • Approx. 2 track days per month in summer
  • HP+ on fronts, stock calipers.
  • Driving instructor, typically lap faster 4-10 secs faster than others in same car (2:30 typical lap)
  • Light and smooth on the brakes at the track
Could there be this much heat being generated that these bolts are getting weakened by the heat?
I am working on completing the brake cooling this weekend regardless (ducts routed through to centre of rotor backside) and this will obviously add much cooling, but curious if anyone has had similar issues with breakage?
I used to run a Miata in Time Attack years ago and just pounded that car every weekend, and never had issues of this kind.
Old 08-12-2014, 02:25 PM   #82
Broken Bolts.
Background:
  • Winter driving
I'd recommend you use a torque wrench, and use anti-seize on the wheel studs. Make sure the other bolts are also clean, and if you're changing things regularly, also use anti-seize, and make sure to re-torque them after a session of getting hot.
Most anti-seize has a 1500F+ heat tolerance; the stuff we ship with our lug nuts is 2000F+.
Old 08-12-2014, 02:32 PM   #83
Slick
Slick's Avatar
Most anti-seize has a 1500F+ heat tolerance.
I always use a torque wrench and never air-tools, crack them with a pivot bar and then remove with a cordless drill (re; wheel nuts).
Any of the new brake bolts going back on have been getting anti-seize already, but will do so for the wheel studs as well.
Just very strange with the breakage of the factory bolts upon first removal.
Old 01-22-2015, 05:52 PM   #84
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
Late bump & helping others in the future.
I just ordered some GT3 brake ducts from Porsche of Beverly Hills, and they are $7.11 each. Part number 997 341 483 92 for the Left and 997 341 484 92 for the right.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
TF Brake Duct Cooling Kit Touge Factory Tracking / Autocross / HPDE / Drifting 77 06-11-2015 07:01 AM
Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! eauto Brakes, Suspension, Chassis 255 10-15-2014 01:45 PM
APR Performance FRS/BRZ Brake Cooling Kit vividracing Brakes, Suspension, Chassis 0 08-08-2013 04:03 PM
TF Brake Duct Cooling Kit Touge Factory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 33 02-19-2013 06:04 PM
Brake cooling duct kit tranzformer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 12-14-2011 01:37 PM
