Old 12-13-2011, 06:45 PM   #1
tranzformer
Delights in pure handling
tranzformer's Avatar
Drives: Zoom Zoom
Brake cooling duct kit
Looking at brake cooling kits for other cars, seems like ~$200-300 will do the job for the kit; ducts to fit where fog lights go, duct hose, brake backing plates (direct air to center of rotor) and the misc hardware.
Is this something that would be worthwhile for someone who occasionally tracks/auto-x the car + mostly DD, or would this be better suited for someone who races their car more often than that? I can't see myself racing more than a few times a year. But it seems like a fairly "cheap" & easy upgrade to get some brake performance in return.
tranzformer is offline   Reply With Quote
Old 12-13-2011, 08:20 PM   #2
ucla bruin
Drives: Daily
If you're racing a few times an year, I would probably say you won't need it. Not a lot of people will need brake ducts, unless you're hardcore and really take advantage of the full braking power (which most of occasional track goers don't).
I'd put the $200-$300 in tires or suspension, if your goal is to build it for track
ucla bruin is offline   Reply With Quote
Old 12-13-2011, 08:21 PM   #3
ucla bruin
Drives: Daily
Oh and pads. Probably tires and pads.
Old 12-13-2011, 08:57 PM   #4
tranzformer
Drives: Zoom Zoom
Thanks. Is it possible to find a set of pads that will do a good job at DD and the occasional track use without being overly loud and dusty?
To be honest the idea of the cooling duct sounds cool, even if not really needed for the occasionally raced car.
Old 12-13-2011, 09:18 PM   #5
LSxJunkie
LSxJunkie's Avatar
Drives: Car
You're not going to need cooling ducts unless you're HPDE-ing the car on a brake heavy track, and even then that will come after pads and fluid (and possibly rotors. Nobody knows how good the cooling is on the stock rotors yet.)
LSxJunkie is offline   Reply With Quote
Old 12-13-2011, 09:28 PM   #6
JDLM
JDLM's Avatar
Drives: 2009 BMW 335i
Invest in rotors/brake fluid/lines (and hopefully they are Impreza parts) so it will be cake
AWE90/ZSP/ZPP/2XA/NAV/HID/DPE////M/EAS/Disma
JDLM is offline   Reply With Quote
Old 12-13-2011, 10:31 PM   #7
Racecomp Engineering
The car should do well with just good pads and fluid. The thing about brake ducts though is they always help and they will make your pads and rotors last a lot longer.....
- drew
Old 12-13-2011, 10:38 PM   #8
tranzformer
Drives: Zoom Zoom
- drew
I assume you mean for a car that is frequently tracked or do you also mean for a car that is occasionally tracked and a DD?
Old 12-14-2011, 12:04 AM   #9
Frequently tracked with serious tires (r-comps) I'd say brake ducts really should be on everyone's list.
Occasionally tracked I'd say optional, but nice to have.
- drew
Old 12-14-2011, 03:30 AM   #10
ucla bruin
Drives: Daily
Yes, very possible but then again you're asking for the balance between DD pads and track pads, which always have a give and take relationship.
Good track pads are not DD friendly (without proper bed-in). DD pads won't withstand the heat from tracking.
For entry tracking and DD with low dust and zero noise, you can check out Hawk's HPS. I'm sure it'll have higher heat tolerance than stock pads. You can always have another set of pads just for track and switch them out before you head out. There are tons of more aggressive ones out there, people will share their experiences. If it were me, I'd get carbotechs XP8.
Save your money for pads and tires and fluids. You'll notice huge difference with pads and tires. Fluids are necessary because it's part of your consumables, maintenance cost.
See you at the track this weekend!
Old 12-14-2011, 05:48 AM   #11
blur
ლ(ಠ益ಠ)ლ
blur's Avatar
Drives: E36 5.7 V8
I prefer CL brake pads.
http://www.essexparts.com/shop/brake...-overview.html
I wish I was cool enough to have an FR-S
blur is offline   Reply With Quote
Old 12-14-2011, 11:05 AM   #12
I hate hate hate Hawk HPS. I faded them backing out of the driveway and they have awful bite.
I'm not a Hawk hater. I do like their real track pads. But HPS is not track worthy....a downgrade from stock IMO.
Stoptech has a good sporty street pad that can take a little abuse.
- Andrew
Old 12-14-2011, 11:13 AM   #13
LSxJunkie
LSxJunkie's Avatar
Drives: Car
- Andrew
This. The HPSs I ran had crap bite. They held up to heat better than stock GTO pads, but worse than stock G35 Brembo pads. I should have gone with Porterfields.
Old 12-14-2011, 11:21 AM   #14
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
- Andrew
Hawk DTCs I'm a fan of, still a fan of blues even though they have plenty of drawbacks (I guess it's more of nostalgia for me with blues :P ).. Carbotech is my current choice..
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
brake override DOES NOT diminish heel & toe 4agze Scion FR-S / Toyota 86 GT86 General Forum 31 09-17-2012 04:43 AM
forgo foglights for air duct to cool brakes? Slide Scion FR-S / Toyota 86 GT86 General Forum 13 11-30-2011 07:58 AM
FR-S Rear brake light... MF_DEUCE FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 70 05-05-2011 03:53 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 10:28 AM
Brake override system in the FT-86? mrKiKaZ Scion FR-S / Toyota 86 GT86 General Forum 10 02-22-2010 11:33 AM
