#43 |
Weight Nazi
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Yeah, I'm not too worried about it. Like you said, if everything's perfect, it's still really tight. Between all the mismatched aftermarket parts I have, it's to be expected every once in a while, I guess.
#44 |
noticed that no one mentioned this but in the videos i noticed your missing your reverse lock out plate , which is why your lock out in non functional and probably why it was hitting the drive shaft
#45 |
refer to the pictures in post #4 and #5 in the following thread
http://www.ft86club.com/forums/showthread.php?t=31340
#46 |
Weight Nazi
#47 |
Boosted
Drives: Not a supra....yet
#48 |
Weight Nazi
I did not realize that's the reverse lockout plate. I thought the flat black plate that the four 10mm bolts go through was the reverse lockout plate. Man, this is great news. But I hope I can find it.
#49 | |
Weight Nazi
#50 |
Glad I could help lol
#51 |
#52 |
Weight Nazi
I was super confused about it. I eventually just chalked it up to magic. That was months ago though, so I've gotten used to the idea of it running on magic. Now I totally see it just smacks into the vertical part of the plate.
#53 |
fastest frs in sbg
Drives: sick ass ultramarine frs
Lol
2013 ultramarine frs sold
2014 turbo ultramarine frs Sold 2014 firestorm frs |
#54 | |
Drives: FRS
#55 |
Weight Nazi
You could probably put washers underneath the base of the shifter. Personally, I'd rather grind the linkage because it doesn't offset the geometry at all, but I'd be willing to bet that would work.
#56 |
Weight Nazi
Just kidding. I just watched that second video I posted and remembered the black plate with the 4 bolts doesn't determine the height of the shifter. So... grinding it is still my only idea.
| DIY: Driveshaft Shop (DSS) Carbon Fibre Driveshaft | F1point4 | DIY (Do-It-Yourself) Guides | 67 | 04-17-2021 05:21 PM |
| Kartboy, Driveshaft shop, Cusco, Perrin, ACT & Competition Clutch @OAKOS Automotive | OAKOS Automotive | Transmission and Driveline | 163 | 01-19-2015 01:44 PM |
| New The Driveshaft Shop Carbon Fiber 1-Piece Driveshaft | Evasive Motorsports | Engine, Exhaust, Transmission | 1 | 09-24-2013 02:27 PM |
| WTB: Driveshaft Shop (or lighter) driveshaft | Anthony | Want-To-Buy Requests | 8 | 08-27-2013 12:30 PM |
| Driveshaft Shop CF Driveshaft installed. | Hawaiian | Engine, Exhaust, Transmission | 5 | 08-13-2013 02:04 PM |
