Old 04-09-2014, 07:09 PM   #43
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Yeah, I'm not too worried about it. Like you said, if everything's perfect, it's still really tight. Between all the mismatched aftermarket parts I have, it's to be expected every once in a while, I guess.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 04-10-2014, 08:26 PM   #44
pandora
noticed that no one mentioned this but in the videos i noticed your missing your reverse lock out plate , which is why your lock out in non functional and probably why it was hitting the drive shaft
pandora is offline   Reply With Quote
Old 04-10-2014, 08:32 PM   #45
pandora
refer to the pictures in post #4 and #5 in the following thread
http://www.ft86club.com/forums/showthread.php?t=31340
Old 04-10-2014, 09:27 PM   #46
Anthony
Weight Nazi
Anthony's Avatar
Old 04-10-2014, 09:28 PM   #47
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Wow really... @Anthony took it off to save weight too
Sent from my IBrick
Old 04-10-2014, 09:28 PM   #48
Anthony
Weight Nazi
Anthony's Avatar
I did not realize that's the reverse lockout plate. I thought the flat black plate that the four 10mm bolts go through was the reverse lockout plate. Man, this is great news. But I hope I can find it.
Old 04-10-2014, 09:29 PM   #49
Anthony
Weight Nazi
Anthony's Avatar
Sent from my IBrick
Yeah... that's right...
Old 04-10-2014, 09:30 PM   #50
pandora
Glad I could help lol
Old 04-10-2014, 11:04 PM   #51
Luis_GT
LMFAO... how'd you think the lock out worked...
Old 04-10-2014, 11:13 PM   #52
Anthony
Weight Nazi
Anthony's Avatar
I was super confused about it. I eventually just chalked it up to magic. That was months ago though, so I've gotten used to the idea of it running on magic. Now I totally see it just smacks into the vertical part of the plate.
Old 04-12-2014, 02:51 AM   #53
sosick
fastest frs in sbg
sosick's Avatar
Drives: sick ass ultramarine frs
Lol
2013 ultramarine frs sold
2014 turbo ultramarine frs Sold
2014 firestorm frs
sosick is offline   Reply With Quote
Old 03-08-2016, 06:44 AM   #54
Binary_fission
Binary_fission's Avatar
Drives: FRS
Originally Posted by tom@kartboy View Post
No idea on the Perrin bushing. Tho it does look quite similar to ours...
Swap that out for our bushings and make sure that the angle of the shifter points towards the back. I ran that same setup on my BRZ before i sold the DS and had no issues.
Feel free to email me directly if you have any other questions.
Tom whats your email ? I just installed my driveshaft and i got same issue, mine is aluminum driveshaft. Im not really down to grind the shift link, like anthony fixed, is there any other way to fix this issue?
Binary_fission is offline   Reply With Quote
Old 03-08-2016, 01:00 PM   #55
Anthony
Weight Nazi
Anthony's Avatar
You could probably put washers underneath the base of the shifter. Personally, I'd rather grind the linkage because it doesn't offset the geometry at all, but I'd be willing to bet that would work.
Old 03-08-2016, 01:11 PM   #56
Anthony
Weight Nazi
Anthony's Avatar
Just kidding. I just watched that second video I posted and remembered the black plate with the 4 bolts doesn't determine the height of the shifter. So... grinding it is still my only idea.
DIY: Driveshaft Shop (DSS) Carbon Fibre Driveshaft F1point4 DIY (Do-It-Yourself) Guides 67 04-17-2021 05:21 PM
Kartboy, Driveshaft shop, Cusco, Perrin, ACT & Competition Clutch @OAKOS Automotive OAKOS Automotive Transmission and Driveline 163 01-19-2015 01:44 PM
New The Driveshaft Shop Carbon Fiber 1-Piece Driveshaft Evasive Motorsports Engine, Exhaust, Transmission 1 09-24-2013 02:27 PM
WTB: Driveshaft Shop (or lighter) driveshaft Anthony Want-To-Buy Requests 8 08-27-2013 12:30 PM
Driveshaft Shop CF Driveshaft installed. Hawaiian Engine, Exhaust, Transmission 5 08-13-2013 02:04 PM
