Old 04-01-2014, 07:04 PM   #1
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Driveshaft Shop CF + Kartboy SS Conflict.
I finally received my driveshaft last night and just finished installing it a little while ago. There's a huge problem though. The driveshaft is hitting the shifter linkage when the car is in neutral, and even more so in 2nd, 4th, and 6th. It clears it in 1st, 3rd, and 5th, but barely. The only idea I can come up with is to grind the shifter linkage down a bit where it's hitting, but I feel like there has to be a smarter way of solving this problem.
I tried searching to see if someone else has this shifter and driveshaft, but I haven't had any luck so far. So I don't even know if this combination would always do this, or if it's just my particular setup.
[ame="https://www.youtube.com/watch?v=umlPUhGJXCc"]Driveshaft Shop CF vs. Kartboy short shifter - YouTube[/ame]
Edit: If no one comes up with a better solution by the time I get off work tomorrow, I'm just going to grind that fool down and call it a day.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 04-01-2014, 07:17 PM   #2
Calum
That Guy
Drives: 2013 asphalt FRS MT
Interesting. It might be worth it to see if the problem is there with the oem shifter if you still have it. I don't know if I'd want those parts all that close as the transmission can move a fair amount even at factory power. Please keep us updated on your findings.
Sent from my samstone
Old 04-01-2014, 07:20 PM   #3
Anthony
Weight Nazi
Anthony's Avatar
The video will make this post 1,000 times better. It's at 60% right now.
Old 04-01-2014, 07:35 PM   #4
Anthony
Weight Nazi
Anthony's Avatar
Video is now in the OP. BEHOLD THE BULLSHIT!!
Old 04-01-2014, 07:47 PM   #5
Luis_GT
I don't think the shifter should have up and down movement...
Old 04-01-2014, 07:48 PM   #6
Anthony
Weight Nazi
Anthony's Avatar
Seems normal to me. I was looking at that, I don't know what would keep it from having that vertical play in it.
EDIT: Also, when I pull up on it, I move the reverse lockout up too, so it doesn't move nearly as much as it appears to.
Old 04-01-2014, 07:54 PM   #7
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
Is it possible that the rear shifter bushing is upside down? That might make the linkage sit lower. Just a guess.
- AdrianG
AdrianG is offline   Reply With Quote
Old 04-01-2014, 07:57 PM   #8
Calum
That Guy
Do you have a Kartboy rear shifter stay bushing, or something similar, installed? Is it perhaps installed upside down?
edit; yeah, what Adrian said.
Old 04-01-2014, 08:01 PM   #9
AdrianG
I know the kartboy kit comes with a bushing just like the Perrin bushing I have. The bolts should be at the bottom, with the flat side down.
- AdrianG
Old 04-01-2014, 08:06 PM   #10
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Wow, I'll be watching this one closely as I have a KB SS and a driveshaft is on my list.
Decay107 is offline   Reply With Quote
Old 04-01-2014, 08:08 PM   #11
Anthony
Weight Nazi
Anthony's Avatar
I installed that thing quite a while back. Pretty sure I made sure not to install it upside down. It seems like installing it upside was either impossible or would've made it really awkward. I still have the exhaust and driveshaft installed, but I'll go out there and see if I can see the bushing.
Old 04-01-2014, 08:09 PM   #12
Anthony
Weight Nazi
Anthony's Avatar
Yep, it's flat side down. I can read the Perrin logo.
Old 04-01-2014, 08:10 PM   #13
AdrianG
Then I'm out of ideas.
- AdrianG
Old 04-01-2014, 08:23 PM   #14
Anthony
Weight Nazi
Anthony's Avatar
Sad news. Here's a picture of it though, just to double check that I'm not retarded.
DIY: Driveshaft Shop (DSS) Carbon Fibre Driveshaft F1point4 DIY (Do-It-Yourself) Guides 67 04-17-2021 05:21 PM
Kartboy, Driveshaft shop, Cusco, Perrin, ACT & Competition Clutch @OAKOS Automotive OAKOS Automotive Transmission and Driveline 163 01-19-2015 01:44 PM
New The Driveshaft Shop Carbon Fiber 1-Piece Driveshaft Evasive Motorsports Engine, Exhaust, Transmission 1 09-24-2013 02:27 PM
WTB: Driveshaft Shop (or lighter) driveshaft Anthony Want-To-Buy Requests 8 08-27-2013 12:30 PM
Driveshaft Shop CF Driveshaft installed. Hawaiian Engine, Exhaust, Transmission 5 08-13-2013 02:04 PM
