Old 10-01-2019, 03:22 PM   #15
pevsfreedom
Drives: 2014 BRZ
Thanks for your help. As far as I could tell they both look the same (M/T)?
New
Old
My dad (much more of a car guy than me) is saying the nipple is a non issue and to just replace the hoses and leave it capped.
pevsfreedom is offline   Reply With Quote
Old 10-01-2019, 03:32 PM   #16
New
Old
Managed to get pics open on phone and yeah you are good for the engine. That nipple looks like it may be part of a turbo oil system? Anybody? I would not just leave it capped with that lightweight dust cap. I would want something that can take the heat and possible pressure.
Old 10-01-2019, 04:17 PM   #17
Tonrogs
Drives: 2014 BRZ Limited, Satin White Pearl
It looks to me like someone did their own pcv system and returned it into the front cover through that nipple. Both pcv ports T into 1 line, which then is dumping back into the oil through the front cover. You could keep this, BUT... You should add an air-oil separator to keep the gunk from entering back into your oil. Or, return to stock configuration and just simply cap the nipple on the front cover. Cap it with a thick rubber cap and clamp it.
By doing this, they eliminated the blow by from the pcv from going into the intake.
'14 SWP BRZ 6MT | FBM built 9:1cr engine w/ GTX3076R Turbo | Mazworx CD009 trans swap | EcuTek | Jackson Racing Dual Oil Cooler/Radiator | SPAL fans | JDL 3" Dual Resonated OP/FP | Perrin 3" | Radium Dual Cans | 18" Rota Titans | M85 3.73 diff | DSS 1k axles | And more....too much more....ugh.
Tonrogs is offline   Reply With Quote
Old 10-01-2019, 07:25 PM   #18
pevsfreedom
Drives: 2014 BRZ
We did take all the hoses off and were planning just clamping that cap on, or something a bit higher quality.
Old 10-01-2019, 07:40 PM   #19
solidsnake11
Drives: brz
It might pay to pull the steel oil pan and clean the pickup and have a look at what's in there. Its not a very hard job, seal with ultra grey.
Could you post a picture of the oil plug on top of the motor in the front?
solidsnake11 is offline   Reply With Quote
Question about engine knock? chaoskaze Engine, Exhaust, Transmission 12 06-09-2016 05:49 PM
BRZ Blown engine question Mujen84 Forced Induction 118 04-02-2014 05:04 AM
Engine Oil Question wodnr1215 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 12 11-12-2013 10:42 PM
Engine Noise Question TONYpepperon1 Issues | Warranty | Recalls / TSB 13 09-01-2013 05:22 AM
Engine Question alex05 Engine, Exhaust, Transmission 4 02-21-2012 06:08 AM
