Old 10-22-2014, 08:19 PM   #1
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Question about engine knock?
Sorry, i'm a total noob on this.
Lately I notice my engine does this tiny knock? It feels like a small thump from time to time when it's idling. (and only when idling) .... Is this normal?
Being skeptical and connecting dots in my head ever since my car made a terrifying screeching sound trying to start back on Monday after an hour of highway driving. I release the clutch after I heard that (like 3sec ish) and restart again fine thou.
Old 10-23-2014, 12:06 AM   #2
JohnJuan
JohnJuan's Avatar
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
Is there any chance you could post a video? Does the tach move oddly when this happens?
JohnJuan is offline   Reply With Quote
Old 10-23-2014, 12:14 AM   #3
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
I dont think a video will show thou, I guess I need to find a fellow 86er in my area to sit in my car. The small thump is evidently there when it happens thou.... or maybe I need to stop using von's (safeway) 91 lol..... cuz its the only cricket free gas in town that I know of. My friend tells me I'm just playing with my head since no CEL.
Old 10-23-2014, 12:16 AM   #4
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
Mods?
Are you sure you are not feeling a misfire maybe? Does it get louder as you rev it?
Doubtful if it is a small intermittent thump at idle that it is rod knock or detonation.
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
Old 10-23-2014, 07:48 AM   #5
Kodename47
Kodename47's Avatar
Drives: UK GT86
AC compressor clutch at idle would be my guess.
.: Stealth 86 :.
Kodename 47 DJ:
Old 10-23-2014, 02:08 PM   #6
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Im going with @woode on this; it would be louder across the entire rev range directly preportional to rpms.
But we can help about as much as a blind man in a dark room.
We need some logs, from either you or the tuner.
Old 10-23-2014, 02:18 PM   #7
GotBRZ1691
GotBRZ1691's Avatar
Drives: 2014 Subaru BRZ Limited 6smt
My guess is its just the sound a boxer engine makes. They are not the best sounding. Plus the tensioner pulley makes a little noise because it bounces some.
I always think my car is making weird noises, and it just came back from the dealer so I know it is good.
Edit: its a knock sounds and not a tick sound. My crickets only happened at idle
GotBRZ1691 is offline   Reply With Quote
Old 10-23-2014, 05:04 PM   #8
woode
Boosted Member
woode's Avatar
Ain't this the truth.
I quit trying to keep track of all the different noises my engine makes. I used to stress over every chirp, squeak, clunk, tick, etc. until I just accepted that it's normal. ..or maybe it's not and my engine is going to explode into a million pieces one of these days.
Old 10-23-2014, 06:37 PM   #9
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
My engine in my old GC has sounded like OP's problem for years still truckin along like that top gear toyota truck.
Old 10-23-2014, 07:01 PM   #10
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
just stuff in the engine.
You wont have knock at idle unless something is REALLY wrong. And it would be really obvious because your car would run horribly
Old 10-23-2014, 07:29 PM   #11
Mr.Ferret
3D Artist
Drives: 2015 White GT86 MT
Ive got what i think might be a similar issue.
I've got about 1800Km's on my car (1100 miles roughly) had my check over at 1300, i now have a slight well i don't know what you would call it, when you turn the car on cold it stays at high revs then drops, mine sits just on 600revs at idle and the needle moves a tiny bit up and down every now and then, the car also occasionally gives the tineyst little shake, like what happens if you dont give it enough revs and its going to stall but only the tiniest bit and not all the time. Bit weird but only happens at idle, no issues with reving or when moving.
Mr.Ferret is offline   Reply With Quote
Old 10-23-2014, 07:34 PM   #12
leoh007
leoh007's Avatar
Drives: 2014 Monogram
I had the same issue, OFT changed the RPM idle and now sits perfectly at around 700-750ish with absolute no rough idling or "dip". I Highly recommend this
leoh007 is offline   Reply With Quote
Old 06-09-2016, 05:49 PM   #13
Norinradd
Drives: 2013 frs
open flash tunerÉ
2013 silver frs, injen intake, agency power header, hks exhaust, no kitties, ecutek tune
Norinradd is offline   Reply With Quote
Engine Knock sound issue nos145 Issues | Warranty | Recalls / TSB 65 10-20-2019 04:57 PM
Knock Correction vs Knock Correction Learn values? swift996 Software Tuning 19 11-03-2015 10:09 PM
Is engine knock normal for the FA20? Cal3000 Engine, Exhaust, Transmission 17 05-20-2013 01:12 PM
anyone experience engine knock on 91 octane? chenshuo BRZ First-Gen (2012+) — General Topics 15 01-13-2013 07:10 PM
Engine Question alex05 Engine, Exhaust, Transmission 4 02-21-2012 06:08 AM
