Old 03-11-2018, 10:11 PM   #15
Kushkaki
Kushkaki's Avatar
Drives: Sold 16 FRS, 22 Neptune 86 on order
Originally Posted by VoltsFRS2013 View Post
225 Wheels? 225 is a tire size.
Wow I cant believe I let that slip.. thanks!
Kushkaki is offline   Reply With Quote
The Following User Says Thank You to Kushkaki For This Useful Post:
VoltsFRS2013 (03-11-2018)
Old 03-11-2018, 10:12 PM   #16
Kushkaki
Kushkaki's Avatar
Originally Posted by Impureclient View Post
225/45/17 (17x7.5) +45 with 20mm spacer front / 25mm spacer rear front camber 0 / rear camber -1.7
That looks absolutely gorgeous!
Old 03-12-2018, 05:27 AM   #17
JD001
JD001's Avatar
Drives: Subaru BRZ
[QUOTE=Kushkaki;3056884]stock wheels and stock height, so thank you! I may go 20/25 F/R...[/QUOTE
My car with 20f and 25r.
The Following User Says Thank You to JD001 For This Useful Post:
Kushkaki (03-17-2018)
Old 03-12-2018, 12:32 PM   #18
SCQTT
ZWEI KOLBEN
SCQTT's Avatar
Drives: 2017 86 Halo 6MT
Originally Posted by r3myx626 View Post
If you look up the specs the 225/45R17 PS4S are pretty heavy compared to stock. Just in tire alone he's adding a bit over 6lbs in weight to each corner. Add in spacers and you're really going in the other direction as far as adding performance....if you care for those sort of small improvements.
Yes, and this is considered "unsprung weight" which has a huge effect on handling and suspension & braking performance as well.
SCQTT is offline   Reply With Quote
Old 03-12-2018, 04:03 PM   #19
Leonardo
Country Boy 4 Life
Leonardo's Avatar
IDK what you are talking about. Tirerack.com has the 225/45/17 PS4S listed at 21lbs; a one pound increase over the stock primacys.
I LIKE TIRES!
Old 03-20-2018, 10:11 PM   #20
r3myx626
r3myx626's Avatar
Drives: 2015 Subaru BRZ Limited ISM
Straight From Michelin's website:
Source:https://www.michelinman.com/upload/michelin_us/specifications/specs-pilot-sport-4s.pdf
r3myx626 is offline   Reply With Quote
Old 03-24-2018, 08:11 PM   #21
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
Wonder if that's a misprint considering that the 225/50 is almost 3 lbs lighter than the 225/45.
JimmyMac is offline   Reply With Quote
The Following User Says Thank You to JimmyMac For This Useful Post:
nico_rsx (03-25-2018)
Old 03-25-2018, 02:01 AM   #22
nico_rsx
Drives: BRZ 2017 Pure Red, MT
This michelin table make no sense it's a mistake for sure.
The 225/45/17 can't be heavier thant the 225/50/17. It got the same width, but less height.
This can be confirmed by looking at the same size in 18", in that case the 225/50/18 is heavier than th 225/45/18
nico_rsx is offline   Reply With Quote
Old 06-01-2018, 06:00 PM   #23
chree
Drives: 2014 BRZ Limited
Called Michelin re: 225/45ZR17 Pilot Sport 4S at 26.85 pounds, they say "It's 26.85", then online chat with Michelin: "It's 26.85". Call Tire Rack, Felix, extension 4497, goes the extra mile and has one weighed... correct weight is 21.0. I purchased and confirm:
Next to an original 215/45R17 Primacy HP:
chree is offline   Reply With Quote
The Following 2 Users Say Thank You to chree For This Useful Post:
JimmyMac (06-01-2018), Leonardo (06-05-2018)
Old 06-01-2018, 06:52 PM   #24
rvoll
Drives: 2018 BRZ Limited, 2017 Sportage
I just replaced my new Primacy 215 HP's with the 225 PS4S, and the weight increase was only 2 lbs per tire. The weight on the Michelin spec sheet was wrong. If you compare that weight with other tires, you'll see what I mean.
rvoll is offline   Reply With Quote
Old 06-04-2018, 06:24 PM   #25
r3myx626
r3myx626's Avatar
2lbs is way better than 6 and about on par with other options. Thanks for the feedback.
Which upgraded tires for the BRZ? pfaffendorn Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 09-01-2016 09:38 AM
Upgraded Tires Happened Sooner Than Expected wakawaka Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 02-29-2016 05:58 AM
Some thoughts after upgraded tires Drakelee117 BRZ First-Gen (2012+) — General Topics 24 02-11-2015 03:21 AM
Stock wheels + Upgraded Tires vs. Wider wheels + upgraded tires themajesticone Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 08-04-2014 03:49 PM
Retaining driving dynamic with upgraded tires? - frs nixeighty6 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 12-22-2011 02:44 AM
