Old 03-05-2018, 03:16 PM   #1
Kushkaki
Kushkaki's Avatar
Drives: Sold 16 FRS, 22 Neptune 86 on order
Finally upgraded from stock tires to 225 MPS4S!
Loving my decision so far, but I want to get some spacers for a little more umph. Does anyone have a picture of 225 tires with spacers? Really appreciated, thank you!
Kushkaki is offline   Reply With Quote
Old 03-05-2018, 04:05 PM   #2
VoltsFRS2013
VoltsFRS2013's Avatar
Drives: 2022' GR86 Premium 6MT
225 Wheels? 225 is a tire size.
22' Toyota GR86 - Trueno Blue - M/T (CURRENT)
18' Toyota 86 GT Black - Moonslate Gray - M/T (SOLD)
13' Scion FRS - Ultramarine - A/T (SOLD)
VoltsFRS2013 is offline   Reply With Quote
Old 03-05-2018, 04:08 PM   #3
churchx
churchx's Avatar
Drives: 2014 GT86
If it's flush looks you are after, then how much they are spaced outside might be changed by both offset and spacers. Specify what offset/size wheels you have and how much further spaced out you want to find out looks of.
Old 03-05-2018, 04:30 PM   #4
Leonardo
Country Boy 4 Life
Leonardo's Avatar
http://www.ft86club.com/forums/showt...t=59838&page=2
17x7 +48 OEM wheels use a 20-25mm front spacer and a 25-30mm rear spacer to be flush. The term "Flush" is subjective. What some consider flush, others would say pokes a little. You will have to make up your mind what "flush" is.
I LIKE TIRES!
Kushkaki (03-11-2018)
Old 03-05-2018, 10:20 PM   #5
Impureclient
Drives: 2015 FR-S
225/45/17 (17x7.5) +45 with 20mm spacer front / 25mm spacer rear front camber 0 / rear camber -1.7
The Following 3 Users Say Thank You to Impureclient For This Useful Post:
Kushkaki (03-11-2018), Leonardo (03-05-2018), new2subaru (06-01-2018)
Old 03-08-2018, 05:19 AM   #6
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
Please don't put 20-30mm spacers on your car. That's a whole lot of weight just to look "flush"
tyler_win_photo is offline   Reply With Quote
Old 03-08-2018, 02:39 PM   #7
RickyRacer
RickyRacer's Avatar
Drives: 13 FRS
bigger wheels to accomplish the same "look" would add the same amount of weight...
for aesthetic purposes i don't see why not
RickyRacer is offline   Reply With Quote
Old 03-08-2018, 02:48 PM   #8
tyler_win_photo
At least you can put more rubber on it. But yeah, for aesthetics go ahead.
Old 03-09-2018, 12:15 PM   #9
PuslarBrrrz
A spacer will add under 2lb to each corner and its very close to the axis of spin so you won't notice anything..
PuslarBrrrz is offline   Reply With Quote
The Following User Says Thank You to PuslarBrrrz For This Useful Post:
Old 03-09-2018, 01:31 PM   #10
churchx
churchx's Avatar
Drives: 2014 GT86
Actually one may notice change like heavier steering due changed scrub radius. Or if this had been FWD car, increased torque steer.
Old 03-11-2018, 03:13 PM   #11
r3myx626
r3myx626's Avatar
Drives: 2015 Subaru BRZ Limited ISM
If you look up the specs the 225/45R17 PS4S are pretty heavy compared to stock. Just in tire alone he's adding a bit over 6lbs in weight to each corner. Add in spacers and you're really going in the other direction as far as adding performance....if you care for those sort of small improvements.
r3myx626 is offline   Reply With Quote
The Following 2 Users Say Thank You to r3myx626 For This Useful Post:
Kushkaki (03-11-2018), SCQTT (03-12-2018)
Old 03-11-2018, 03:32 PM   #12
JD001
JD001's Avatar
Drives: Subaru BRZ
Are you?
1. Planning to race your car?
2. Planning on setting a land speed record?
3. Planning to set new race track lap times?
If the answers are 'no' to the above then I think making your car look good in your eyes does no harm. Adding a small amount of weight will not dent your car's performance. Tyres, wheels, brake disk weights will vary as there are tolerances that need to be remembered.
My first mod was dropping the car and adding 20mm spacers up front, 25mm at the back. I love the look..
The Following User Says Thank You to JD001 For This Useful Post:
Old 03-11-2018, 04:27 PM   #13
rmr
rmr's Avatar
Drives: FRS 10-series
Originally Posted by Kushkaki View Post
Loving my decision so far, but I want to get some spacers for a little more umph. Does anyone have a picture of 225 wheels with spacers? Really appreciated, thank you!
Are you on stock wheels and stock height or lowered?
Stock height 15mm/20mm or 20/25 spacer F/R would be reasonable, 20/25 might have some poke.
Keep in mind 15mm you will have to extend your lugs, the 20mm spacer can get away with an adapter style bolt on.
rmr is offline   Reply With Quote
The Following User Says Thank You to rmr For This Useful Post:
Old 03-11-2018, 09:10 PM   #14
Kushkaki
Kushkaki's Avatar
stock wheels and stock height, so thank you! I may go 20/25 F/R...
Which upgraded tires for the BRZ? pfaffendorn Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 09-01-2016 08:38 AM
Upgraded Tires Happened Sooner Than Expected wakawaka Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 02-29-2016 04:58 AM
Some thoughts after upgraded tires Drakelee117 BRZ First-Gen (2012+) — General Topics 24 02-11-2015 02:21 AM
Stock wheels + Upgraded Tires vs. Wider wheels + upgraded tires themajesticone Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 08-04-2014 02:49 PM
Retaining driving dynamic with upgraded tires? - frs nixeighty6 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 12-22-2011 01:44 AM
