| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#15 |
Drives: Sold 16 FRS, 22 Neptune 86 on order
| The Following User Says Thank You to Kushkaki For This Useful Post: | VoltsFRS2013 (03-11-2018) |
#16 |
#17 |
Drives: Subaru BRZ
[QUOTE=Kushkaki;3056884]stock wheels and stock height, so thank you! I may go 20/25 F/R...[/QUOTE
My car with 20f and 25r. |
| The Following User Says Thank You to JD001 For This Useful Post: | Kushkaki (03-17-2018) |
#18 | |
ZWEI KOLBEN
Drives: 2017 86 Halo 6MT
#19 | |
Country Boy 4 Life
IDK what you are talking about. Tirerack.com has the 225/45/17 PS4S listed at 21lbs; a one pound increase over the stock primacys.
I LIKE TIRES! |
#20 | |
Drives: 2015 Subaru BRZ Limited ISM
Source:https://www.michelinman.com/upload/michelin_us/specifications/specs-pilot-sport-4s.pdf |
#21 |
Drives: 2013 FR-S, 2016 Miata Club
Wonder if that's a misprint considering that the 225/50 is almost 3 lbs lighter than the 225/45.
| The Following User Says Thank You to JimmyMac For This Useful Post: | nico_rsx (03-25-2018) |
#22 |
Drives: BRZ 2017 Pure Red, MT
This michelin table make no sense it's a mistake for sure.
The 225/45/17 can't be heavier thant the 225/50/17. It got the same width, but less height. This can be confirmed by looking at the same size in 18", in that case the 225/50/18 is heavier than th 225/45/18 |
#23 |
Drives: 2014 BRZ Limited
Called Michelin re: 225/45ZR17 Pilot Sport 4S at 26.85 pounds, they say "It's 26.85", then online chat with Michelin: "It's 26.85". Call Tire Rack, Felix, extension 4497, goes the extra mile and has one weighed... correct weight is 21.0. I purchased and confirm:
![]() Next to an original 215/45R17 Primacy HP:
#24 | |
Drives: 2018 BRZ Limited, 2017 Sportage
#25 |
2lbs is way better than 6 and about on par with other options. Thanks for the feedback.
| Which upgraded tires for the BRZ? | pfaffendorn | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 20 | 09-01-2016 09:38 AM |
| Upgraded Tires Happened Sooner Than Expected | wakawaka | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 14 | 02-29-2016 05:58 AM |
| Some thoughts after upgraded tires | Drakelee117 | BRZ First-Gen (2012+) — General Topics | 24 | 02-11-2015 03:21 AM |
| Stock wheels + Upgraded Tires vs. Wider wheels + upgraded tires | themajesticone | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 18 | 08-04-2014 03:49 PM |
| Retaining driving dynamic with upgraded tires? - frs | nixeighty6 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 14 | 12-22-2011 02:44 AM |
