Old 08-04-2014, 03:36 AM   #1
themajesticone
themajesticone's Avatar
Drives: '13 UM86
Stock wheels + Upgraded Tires vs. Wider wheels + upgraded tires
Lets say I want to stick with the stock wheels but upgrade to Super Sports (215/45ZR17)
Would I be at a huge disadvantage vs. getting an 8" - 8.5" wheel + super sports? How much slower would I be in a track or autoX setting? I know there is more grip/contact patch with a wider wheel/tire combo, but at what point is it a diminishing return? I don't want this to come off as a dumb question.... just want to know do I really NEED wider wheels if I have great preforming tires?
And to spice things up a bit. Lets say I have
Bilstein B8 + RCE Tarmacs on Stock Wheel w/ Super Sports vs. Bilstein B8 + RCE Tarmacs on 8.5" wheel w/ Super Sport
How owned would I get on stock vs. the 8.5" (generally speaking)
themajesticone is offline   Reply With Quote
Old 08-04-2014, 03:52 AM   #2
DAEMANO
Time Traveller
From what I understand, stickier compounds typically trump wider but less sticky at the track. So if you're going to be tracking your car I'd go even more aggressive like RE-11A 's than the Pilot Sports at stock width.
If you're going to be AutoXing, then wider is generally considered better. Get them as wide as you can.
If you're staying on the street, then I'd look at cheaper (slightly less sticky) tires all around than PSS like BFG COMP2s, Direzza DZ102s, Hankook V12 Evo 2, etc. but that's me trying to save you money.
Old 08-04-2014, 03:57 AM   #3
themajesticone
Drives: '13 UM86
What about street with some track driving every month or two? I typically don't do auto-x. I may in the future but after my first track day this weekend, I'd like to do that more often.
Old 08-04-2014, 03:59 AM   #4
DAEMANO
Time Traveller
I'd go RE-11A at stock width or go to a 225" section but nothing wider on stock power, brakes and suspension. That should be plenty of tire.
Old 08-04-2014, 04:02 AM   #5
DAEMANO
Time Traveller
Hit up @ATL BRZ 's build thread, he tracked on RaceComp yellows + RE-11A's extensively before upgrading to RaceComp Tarmac 2s.
HERE http://www.ft86club.com/forums/showthread.php?t=13157
Old 08-04-2014, 10:40 AM   #6
Firestorm_86
Drives: FRS
The bigger wheel, means more weight, and more expensive tires. On top of that, unless its the same compound, you can get the same grip with a lighter, cheaper setup.
Firestorm_86 is offline   Reply With Quote
Old 08-04-2014, 11:15 AM   #7
ZionsWrath
Thanks
ZionsWrath's Avatar
I just weighed my new wheel/tire
17x8 with 225/45 and on my super accurate nano technology 10 year old sister's bathroom scale
43.5 lb
I believe stock is ~40.5 lbs
I can weigh my stocks when I change brake pads tomorrow. (but not too accurate as they have some street and track time on them)
Old 08-04-2014, 11:18 AM   #8
themajesticone
Drives: '13 UM86
@ZionsWrath @Firestorm_86 @DAEMANO where do you guys go for wheels and tires online?
Old 08-04-2014, 11:19 AM   #9
horrorbiz
horrorbiz's Avatar
Drives: ‘22 BRZ Limited
Stock size will be faster: http://www.roadandtrack.com/special-...transformation
horrorbiz is offline   Reply With Quote
Old 08-04-2014, 11:22 AM   #10
ZionsWrath
Thanks
ZionsWrath's Avatar
tirerack, they mount and balance free and for me close enough to drive and pick up so no shipping charge, just gas/time
Old 08-04-2014, 11:50 AM   #11
Firestorm_86
Drives: FRS
Originally Posted by horrorbiz View Post
I agree. They went from a 215 17, to a 235 18, same compound. Which is more wheel and tire; weight wise. I run 17x7.5 Wedssports with a 225 Michelin Pilot Sport AS3's. It's a good halfway point. Slightly wider tire (so a little more weight), but I shed weight with the lighter than stock wheels.
@themajesticone
My wheels came from Vivid Racing, but I'd just as readily recommend CounterSpace Garage. Tires, I went with a local place that'll price match and has good service, but I used to use Costco.
@ZionsWrath what wheels/tire are you running?
Also, a word on wheels. You can go with the cheap stuff, but you'll likely pay for it in weight. You'll balance looks and performance. If you want both, it's $$$. You can go Rota, and get the same look, but you'll be hard pressed to get the same performance/weight. On the other hand, you can sell a kidney and get Volks. Inbetween, there's WedsSport, SSR, and Enkei, among many others.
Old 08-04-2014, 11:55 AM   #12
ZionsWrath
Thanks
ZionsWrath's Avatar
17x8 +45 Enkei PF01
225/45 RE11A
I haven't use them yet, I'm registered for track event on the 13. Waiting on brake pads to show up, I hope they fucking do lol
Old 08-04-2014, 11:59 AM   #13
Firestorm_86
Drives: FRS
17x8 +45 Enkei PF01
225/45 RE11A
Those are pretty. Black or silver?
The RE11's are too much tire (or not enough?) for my DD and mountain run uses. If I ever move back to a place where it doesn't get to freezing I'll run summers.
Old 08-04-2014, 12:05 PM   #14
ZionsWrath
Thanks
ZionsWrath's Avatar
BLAAACK
Wider tires on stock wheels buzznasa Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 30 01-21-2019 01:55 PM
Upgraded to HRE wheels on our Turbo BRZ Crawford Performance Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 28 04-03-2014 11:22 PM
17” OZ Alleggerita wheels with stock 215/45-17 tires… 17x7.5 or 17x8 wheels? SteveH Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 02-14-2013 10:26 PM
Track Test: Edmunds 2013 Scion FR-S with Upgraded Wheels and Tires Pulls 1.0g! poormans_LFA Scion FR-S / Toyota 86 GT86 General Forum 38 09-08-2012 12:46 AM
Retaining driving dynamic with upgraded tires? - frs nixeighty6 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 12-22-2011 01:44 AM
