Old 02-25-2016, 04:22 AM   #1
wakawaka
Drives: 2016 BRZ Hyper Blue
Upgraded Tires Happened Sooner Than Expected
So I've been driving the car for a couple weeks now and it's been awesome. Buuuuuut man these tires skate over the surface like nobody's business. I was thinking of waiting until I wore these down a bit before getting a wheel/tire upgrade, but Costco had this deal on Michelin PSS annnnddd...
I just had them put on today. Thank the heavens. So much better. Still running stock wheels but we fit 225 on them. Ride is much improved but still has that oily coating they come with from factory. But I'm stoked to ride with these guys! I had PSS on my last car, so it was a pretty easy decision to go back.
Anyways, I noticed they have a 30k mile warranty. I've never applied for the warranty and never really needed to since they treated me so well. But has anyone here gone through the warranty process? What was it like?
wakawaka is offline   Reply With Quote
Old 02-25-2016, 10:41 AM   #2
BBYZILA
BBYZILA's Avatar
Drives: 2013 Firestorm FR-S
I just did the same thing lol
4 michelins and 70 off at costco, will have them installed soon!
BBYZILA is offline   Reply With Quote
Old 02-25-2016, 11:24 AM   #3
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
as long as you got 4 of the same size tires, you have a 30k warranty.
Basically, if they wear out before that, you can get pro-rated replacements
Old 02-25-2016, 11:52 AM   #4
menikmati
Drives: 2015 BRZ, 2005 STI, 2024 Type R
When you buy tires at Costco, do you have to get them mounted? I just noticed that $70 off deal and would just like to buy them, store them and mount them when summer rolls around.
menikmati is offline   Reply With Quote
Old 02-25-2016, 12:41 PM   #5
ap5512
ap5512's Avatar
Drives: 2013 SWP BRZ
^^ I wanted to know the same. I don't mind them installing it but I wonder if they will install on the new wheels that I want to order or does it have to go on the stock wheel/car?
"Don't be a don'ter, do be a doer" - Johnny Wu
ap5512 is offline   Reply With Quote
Old 02-26-2016, 12:55 AM   #6
wakawaka
Costco charges $15 per wheel to have them mounted. That $15 includes mounting, balancing, and disposal of the old tire. But seeing as the tires were still so new, I'm just holding onto them just in case. And actually I think disposal usually runs $1 a tire, so I ended up paying $14 per tire for install. The Costco deal was a little sweeter than just $70 off in that they also gave an extra $30 discount towards install for executive members.
You don't have to have them installed there - if you just take delivery you only pay for the tire, not the install. It was just easier for me to have them installed there, but word of wise - they damaged my wheel. There's small scrubbing/nicks where they mounted the tires. I'm probably going to follow up with them because I took pictures before just in case, but at the same time I don't expect them to actually do anything about it, and I'm not sure if it's worth the hassle.
Old 02-26-2016, 05:35 AM   #7
86 South Africa
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
So quick Q on the size...
I'm waiting for my stock ones to wear out, but the 225's fit without an issue on the stock wheels? I was considering getting some spacers too - but assuming I don't - there is no issue with the wider rubber as normal?
I like driving!
86 South Africa is offline   Reply With Quote
Old 02-26-2016, 05:54 AM   #8
RedBRZ80
Drives: 2013 Red BRZ
He'll, you can get up to a 245/40 on the stock wheel.. But that said a 225/45 isn't that much more and doesn't mess with the speedo that much.
I'm currently on 225/45 on a 17x8 wheel for DD.
RedBRZ80 is offline   Reply With Quote
Old 02-26-2016, 08:09 AM   #9
86 South Africa
Oh wow - didn't realise you could go that big.
I have the high spec (I think it's the equivalent of the BRZ Ltd in the US) which comes with the 17" rims - and don't really want to spend cash on wheels at this stage + the stock wheels really aren't bad.
I like driving!
Old 02-26-2016, 08:28 AM   #10
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
compound is more important then width of a tire for traction and a wider tire on a narrow rim with feel sloppy due to the side wall bulging out and the car will be less responsive. However I ran 225s on OEM and it wasn't bad. Also don't forget wider is heavier
Old 02-26-2016, 11:50 AM   #11
86 South Africa
Luckily I don't have to deal with snow here, just rain. But otherwise reasonably warm temps.
I do think having the slightly wider tyres should be a little more fun... Guess the best would be to try and set and see how it feels - nothing beats personal experience
I like driving!
Old 02-26-2016, 03:29 PM   #12
wakawaka
I did some digging around and was repeatedly told not to go larger than 225. At 235, you should be going up to 7.5. Especially at 245, you should definitely get a wider wheel.
these 225s are wide enough to notice they're bigger than stock, but I'm not getting any rub and my ride has improved considerably. there's grip for days compared to the stock tire, so as much as I'd love fat rubber all around, I'm pretty content with this.
Old 02-27-2016, 04:03 AM   #13
86 South Africa
That's kinda what I was hoping to hear.
I'm not looking for laps records - just that little bit more. I also don't think the downsides to tyres bigger than 225 are worth it for what I want (weight, rubbing, cost, etc)
Thanks... 225s for me next time around
I like driving!
Old 02-28-2016, 09:07 AM   #14
saj
saj's Avatar
Drives: ̶1̶0̶ ̶S̶
Yea, the primacys were a horrible choice for the 86. Remember when all the car journalists talked about how much "fun" it was because the tires were so narrow? Fuck all of them.
saj is offline   Reply With Quote
Some thoughts after upgraded tires Drakelee117 BRZ First-Gen (2012+) — General Topics 24 02-11-2015 02:21 AM
1st Service.?. 6k/6mo/sooner.?. westmansweed BRZ First-Gen (2012+) — General Topics 10 01-13-2015 08:29 PM
Stock wheels + Upgraded Tires vs. Wider wheels + upgraded tires themajesticone Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 08-04-2014 02:49 PM
Track Test: Edmunds 2013 Scion FR-S with Upgraded Wheels and Tires Pulls 1.0g! poormans_LFA Scion FR-S / Toyota 86 GT86 General Forum 38 09-08-2012 12:46 AM
Retaining driving dynamic with upgraded tires? - frs nixeighty6 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 12-22-2011 01:44 AM
