Old 10-15-2016, 09:04 AM   #15
Originally Posted by Terruko View Post
So this came up...
What is it?
Low tire pressure.
p1l0t (10-16-2016)
Old 10-15-2016, 11:08 AM   #16
Braces
Braces's Avatar
Drives: 17 Alfa Romeo 4C
So this came up...
What is it?
A warning that you haven't read your manual yet.
My 2013 Firestorm Red 13 FRS is gone. Bought the next best thing: 2017 Alfa Romeo 4C
Braces is offline   Reply With Quote
The Following 7 Users Say Thank You to Braces For This Useful Post:
finch1750 (10-16-2016), Hot-Lava_Dave (10-16-2016), humfrz (10-16-2016), p1l0t (10-16-2016), shellslinger (10-15-2016), Tectoniic (10-16-2016), Ultramaroon (10-16-2016)
Old 10-16-2016, 03:43 AM   #17
humfrz
So this came up...What is it?
....... because you haven't read your manual.
another ....... because you should be able to figure it out, even if you didn't read your manual.
Now, go put about 35 psi of air in all of your car's tires.
....... that one is just because I felt like it.
humfrz
Old 10-16-2016, 03:45 AM   #18
humfrz
Low tire pressure.
Tcoat has gone soft on us ......
humfrz
Old 10-16-2016, 03:49 AM   #19
Terruko
Terruko's Avatar
Also this, what's it for and how do I use it?
Terruko is offline   Reply With Quote
Old 10-16-2016, 03:54 AM   #20
humfrz
No I just figured if he won't believe that the sound clip he made is a perfectly normal sounding boxer engine ( after asking if it was normal at that) then he would not believe that there is a such thing as a book that tells you all those hidden secrets. Even I sometimes know when to just give up.
Not sure if it is a cultural thing now or just a result of ease of information on the internet but damn it seems people go out of their way to try and find something wrong with their cars sometimes.
Old 10-16-2016, 04:23 AM   #21
humfrz
I think new drivers are overwhelmed with too much information about their cars.
Remember, back-in-the-day, we just looked and listened to "the vital signs".
* car ran out of gas - walk to the next farm and borrow a gallon of gas
* car was billowing steam from under the hood - fill it with ditch water and wrap a rag around the busted radiator hose.
* car vapor locked - place a wet rag on fuel line & re-prime
* tire went flop-flop-flop - put on the spare
* car flooded - hold open the choke with a pen, push accelerator to the floor and hold it while cranking the engine till it started
* car wouldn't stop - downshift and apply emergency brake
* car died at idle - take a screwdriver or a dime and turn idle screw clockwise a time or two.
* car won't fire during damp weather - take off your T-shirt and dry out the distributor contacts
* car is mis-firing - pull plug wires one at a time till you find the fouled plug, pull it and clean it up.
* I'm sure you old timers can add to the list......
Now .......
humfrz
p1l0t (10-16-2016)
Old 10-16-2016, 04:40 AM   #22
humfrz
I am going to dispute this one^!
98% of the time the e brake cables were either seized solid or had snapped years ago.
I am sure that people will counter with "well cars are more complex now". Yes, they are, but the quality of manufacture, vastly improved technology and materials more than make up for that.
I find it entertaining that the same guys that will freak out and tell people to take their at in for a full cooling system flush because somebody put 4 ounces of the wrong coolant in it are also the ones that will change their whole suspension and discuss the merits of FI at length.
humfrz (10-16-2016)
Old 10-16-2016, 01:22 PM   #23
p1l0t
p1l0t's Avatar
#tooReal
Old 10-16-2016, 02:16 PM   #24
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
Low tire pressure.
Wow... I always thought that was the driver flatulence warning!
nextcar is offline   Reply With Quote
Old 10-16-2016, 02:20 PM   #25
That would be a warning light that I would most certainly have to disable.
Old 10-16-2016, 03:17 PM   #26
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Wait, so I should freak out when i ran low on oil and added half a quart of 5-30 to my 0-30 cuz its what I had in the garage? Holy shit my motor is gonna grenade...
Old 10-16-2016, 03:36 PM   #27
humfrz
Your engine is soon to be toast. Mix & match oil weights is a sure way to induce oil channel confusion in the engine. This will completely throw off the VVT (since it's oil controlled) and the valves will be coming from the right at the same time the piston is coming from the left.
Result:
The Following 3 Users Say Thank You to humfrz For This Useful Post:
guybo (10-16-2016), p1l0t (10-16-2016), Ultramaroon (10-16-2016)
Old 10-16-2016, 03:52 PM   #28
Result:
Hey how did you get a pic of my Talon engine after it threw the timing belt?
humfrz (10-16-2016), p1l0t (10-16-2016), Ultramaroon (10-16-2016)
Idling characteristics with bad MAF sensor? mheffel Engine, Exhaust, Transmission 5 10-26-2014 10:56 PM
6 speed m/t idling low Gt86_nick Engine, Exhaust, Transmission 1 01-28-2014 08:54 PM
Idling Issue ericmpena Issues | Warranty | Recalls / TSB 1 11-01-2013 01:21 AM
High idling on new FR-S ndsleep612 Issues | Warranty | Recalls / TSB 19 07-27-2013 11:06 AM
Idling/RPM question Crackseed Hawaii 3 02-25-2013 12:54 AM
