Old 01-28-2014, 07:03 PM   #1
Gt86_nick
Drives: Scion FRS asphalt
6 speed m/t idling low
Not too sure if anyone else has this problem but if I'm sitting at a light in neutral my car will sometimes drop to 4-500 rpm and then will jump back up to around 1000. Is this normal? I only have around 4500 miles on the car
Gt86_nick is offline   Reply With Quote
Old 01-28-2014, 07:54 PM   #2
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Yup, all the stock tunes do this unfortunately. Even the latest ECU revision still has the same problem. With a proper tune you can raise the idle just a bit to avoid the issue.
Xero-Limit is offline   Reply With Quote
Idling Issue ericmpena Issues | Warranty | Recalls / TSB 1 11-01-2013 12:21 AM
High idling on new FR-S ndsleep612 Issues | Warranty | Recalls / TSB 19 07-27-2013 10:06 AM
Idling/RPM question Crackseed Hawaii 3 02-24-2013 11:54 PM
Idling problems Canadian cars Skye CANADA 17 08-28-2012 01:11 PM
Idling and parking brake markmatley Engine, Exhaust, Transmission 1 06-09-2012 07:20 PM
