Old 10-31-2013, 11:59 PM   #1
ericmpena
ericmpena's Avatar
Drives: Subaru BRZ Limited
Idling Issue
Just started today. Yesterday I had to drive home through nearly flooded highway. Not sure if that could've cause this issue, but here's what's happening.
My car is idling at 2000+ rpm's when clutch is in and car is rolling. Taking the shifter out of gear and releasing the clutch sometimes brings the idle back down. This high idle is happening about 80% of the time starting today.
I've read about the idle dip, but I did not find any information about a high 2000+ idle. I should also say that I recorded this issue just now. My car was rolling idle above 2000 rpm for nearly 20 seconds. I had hit the end of the parking lot so I had to turn my car and the idle dropped back to normal. Who knows how much longer it would've been stuck up there.
Any suggestions? Is this a known issue? What damage can it cause my car?
ericmpena is offline   Reply With Quote
Old 11-01-2013, 12:21 AM   #2
humfrz
Originally Posted by ericmpena View Post
Just started today. Yesterday I had to drive home through nearly flooded highway..........
Do you reckon any water got up into the engine compartment? If so, has it dried out good?
I'd take it up on the freeway and give it a good run to warm up/dry out the engine real good.
If that didn't settle it down, you may consider disconnecting the battery for a few minutes (then hook it back up ... ) to see if the idle will re-set.
Or take it into a dealer ....and they will most likely tell you "that's normal" ....
I hope you get it settled down.
humfrz
PS - I don't believe that a high idle will cause any damage to the engine .... just to your nerves.
High idling on new FR-S ndsleep612 Issues | Warranty | Recalls / TSB 19 07-27-2013 10:06 AM
Idling/RPM question Crackseed Hawaii 3 02-24-2013 11:54 PM
Idling problems Canadian cars Skye CANADA 17 08-28-2012 01:11 PM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 06:50 AM
Idling and parking brake markmatley Engine, Exhaust, Transmission 1 06-09-2012 07:20 PM
